ecm on 85
Old Jan 1, 2006 | 11:29 AM
jjgkdg's Avatar
jjgkdg
Default ecm on 85-88
Where is the ecm located on an 85? Wording in my manual is to general. Thanks in advance!
Old Jan 1, 2006 | 12:04 PM
jjgkdg's Avatar
jjgkdg
Anybody?? I did a search and found some pics, looks like it's behind the breadbox. Is this correct??
Old Jan 1, 2006 | 12:08 PM
steveb's Avatar
steveb
It's in the passanger side of the dash. You can remove the hush panel under the dash to get to it.
Old Jan 1, 2006 | 12:11 PM
jjgkdg's Avatar
jjgkdg
By hush panel do you mean the panel directly over your feet/legs on the pass side?? I already have this out and I see nothing.
Old Jan 1, 2006 | 12:26 PM
hoot85's Avatar
hoot85
Remove the black kick panel on the passenger side get out your flashlight and on your back underneath the dash. you will see a long beige plastic piece with 2 bolts burried in a nest of wires. remove the 2 10mm bolts and the ecm with insert will be able to be removed. pull straight down and twist slightly and there is 2 i think 7mm bolts to access the chip if thats what you are looking to do. but if you are removing anything or plugging anything electrical in, disconnect the battery!!!!!!!!!!!!!!!!!!!!!!!!!
Good Luck!
Old Jan 1, 2006 | 01:36 PM
jjgkdg's Avatar
jjgkdg
Thanks, I finally found it. Did'nt stand on my head when I looked the first time.
Old Jan 1, 2006 | 05:24 PM
MrRenoman's Avatar
MrRenoman
Standing on your head is mandatory for working on these cars.
To ecm on 85
