Surging radiator. I cannot fill it
Old Jan 1, 2006 | 08:43 PM
AZC4Guy's Avatar
AZC4Guy
Default Surging radiator. I cannot fill it
Just like the title says. New Hi-vol Edelbrock waterpump. With the thermostat open, the radiator level surges(rises and falls) dramatically, making it impossible to fill up. The happens level or with front end jacked up. 2 different thermostats have been used. This is at idle and at 2k rpm. Temps fluctuate during driving although they tend to be high.
Water flows nicely thru rad core toward the opening. Fluid is very clean.(new motor)
What am I missing? what is my problem? Help/advice greatly appreciated.
Motor is a carbed 383.
Old Jan 1, 2006 | 10:02 PM
jfb's Avatar
jfb
Something isn't right here. I have a Stewart waterpump on my 87 and Stewart claims higher flow than the Edelbrock and I can watch my coolant level drop when I slightly race the engine so I can fill it. You should also be able to do the same and a high volume pump isn't related in my opinion. If you have a bad head gasket leak, cylinder pressure can put air into your cooling system making the level unstable, maybe that is where your problem is.
Old Jan 2, 2006 | 12:13 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Do you have the motor warmed up to tstat temp first?
Old Jan 2, 2006 | 12:17 AM
AZC4Guy's Avatar
AZC4Guy
centrl coaster.... yes... engine is at temp. another interesting note: I added another temp sensor with a seperate gauge, this one on the intake next to the T-stat. While the temp sensor(brand new, replaced old one. new one reads same as old one) in the block may read 240 or even 250 degrees, the temp in the intake is only 190.
If I had a leaking head gasket, wouldn't I notice that in the exhaust?
JFB, you're right.. something isn't right...I'd sure like to find out what.
Old Jan 2, 2006 | 12:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
I've had that happen with the thermostat closed, but never when its open.
Old Jan 2, 2006 | 12:37 AM
jfb's Avatar
jfb
Partial Quote:
________________________________________ _________________
Do you have sweet smelling exhaust and/or white colored exhaust smoke ?
Old Jan 2, 2006 | 12:41 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Could be bad water pump. Take the thermastat completely out and if it surges the pump may be toast. Similar situation with major surges happenned to me, turned out to be water pump.
Old Jan 2, 2006 | 01:21 AM
AZC4Guy's Avatar
AZC4Guy
jfb.. neg. exhaust seems normal.
What if I take the Tstat out and the surging stops? can i safely run the car w/ no T-stat?
Old Jan 2, 2006 | 01:35 AM
CentralCoaster
Don't do it. The t-stat helps keep coolant under pressure in the block, preventing hot-spots (boiling coolant).
Without the t-stat the engine will take forever to warm up, wear faster, and might overflow your overflow tank from over pressure at the cap.
If it's just temporarily, then sure, no prob.
Old Jan 2, 2006 | 03:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
Think drilling an 1/8" hole or two for bypass in the thermostat would help due to the extra output of the pump?
Old Jan 2, 2006 | 03:43 AM
CentralCoaster
drilled thermostats suck. btdt
I have no issues with my Stewart waterpump and regular t-stat. If anything it just costs some extra hp to run it.
Old Jan 2, 2006 | 03:45 AM
AZC4Guy's Avatar
AZC4Guy
I had a drilled T-stat and replaced it because I thought maybe it was the source of the surging.
Old Jan 2, 2006 | 04:02 AM
CentralCoaster
Water pumps can surge if the system is too restrictive, or the pump is oversized, or if there's air in the system. The water basically stops moving intermittently, and the suction pressure at the pump goes away, causing it to flood out of the radiator cap.
I'd make sure the system is burped well, if that doesn't cut it, I'd try a new waterpump.
Old Jan 2, 2006 | 04:13 AM
hippy's Avatar
hippy
What about buying a funnel that has the adapter attached to it so you put in on your radiator like your radiator cap? Depending on the unit you find you can gain 10".
Old Jan 2, 2006 | 04:32 AM
RatC4's Avatar
RatC4
Maybe the wrong rotation direction? Serpentine belt water pumps are reverse rotation, correct?
Old Jan 2, 2006 | 09:21 AM
AZC4Guy's Avatar
AZC4Guy
If it were the wrong rotation would I get any cooling really? Would I see water flowing out of the core rods by the cap? I truly dunno.
Central the burping thing is the problem. I'm tying to burp it, add fluid to top it off when the surging occurs.
Old Jan 2, 2006 | 10:40 AM
mseven's Avatar
mseven
Do you know for sure that the stat is opening, should be able to tell by squeezing upper hose. If you can determine that water is going through the upper at O.T., then I agree w/above, pull stat. to then determine if water pump is the issue.
The other that I have done to help it out was to fill up the block first(you mentioned fresh build) before installing t.stat, so it doesn't get the chance to overheat and maybe kill the stat.
To Surging radiator. I cannot fill it
Old Jan 2, 2006 | 11:21 AM
jfb's Avatar
jfb
Double check the model of waterpump you got against what is supposed to be there. You might have a pump that fits but intended for another engine.
Old Jan 2, 2006 | 11:26 AM
cv67's Avatar
cv67
St. Jude Donor '05
While pouring the coolant, bow up and down at the same rate the coolant surges up and down in the tank
Old Jan 2, 2006 | 11:56 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Now you're getting silly--is that a Zen thing?
