1989 Headlight problem
Old Jan 1, 2006 | 10:01 PM
89vettelou's Avatar
89vettelou
3rd Gear
Default 1989 Headlight problem
Both headlamps started not to open all the way at the same time on my 1989. Can someone give me some direction on where to start? Electrical or motors?
Thank you
Old Jan 1, 2006 | 10:59 PM
jfb's Avatar
jfb
I have an 87 and I don't know if your headlight motors are like mine, I think they are. Unplug one of the headlight motors. If they have 3 contacts then they are like my motors. Unplugged, you can jump 12 v to the connector going to the motor to run the headlights up and down. To open, put +12 to the green wire (C terminal) and - 12v to the white/black (RH motor), white (LH motor) wire. The headlight should open all the way and stop. If it doesn't you have motor problems. If it does open correctly, then you likely have problems with the headlight door relays. There are three relays, a LH relay, RH relay, and an isolation relay for closing the RH headlight. The relays aren't expensive and easily replaced.
Old Feb 17, 2006 | 10:56 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Your bushings could be starting to fail, too. It wouldn't hurt to replace the OEM Delrin bushings.
Old Feb 17, 2006 | 06:03 PM
CorvAdel's Avatar
CorvAdel
Your h/lite motors should have 2 wires, and your model car did not come with relays, but with a h/lite module. This is located under the lh h/lite and attached to the fr. part of the inner sp. shield. I suspect your problem with BOTH motors not operating correctly, to be with the this module. Other 80's GM cars have the same..Pontiac, Camaro etc. I would go to a breaker and try one before doing any h/lite motor work..
Old Feb 17, 2006 | 08:49 PM
Paul G's Avatar
Paul G
I had to replace the Delrin bushings on my 88. Headlight would only open half way, motor would run for a while with the headlight not moving. Will they open all the way by hand? By hand I mean turning the **** on the headlight motor assembly.
Old Feb 17, 2006 | 10:26 PM
PBnf's Avatar
PBnf
My right side light did the same on my 90 coupe. A rebuild kit is about $4.00 from Mid America. It's kind of a pain to fix, but if you work patiently you'll get it. Go to www.corvettefever,com/techarticles, and you'll find one with pictures and all, showing you what to do.
Old Mar 3, 2006 | 11:31 PM
89vettelou's Avatar
89vettelou
3rd Gear
yes, they will open by hand
Old Mar 18, 2006 | 04:18 PM
89vettelou's Avatar
89vettelou
3rd Gear
Default 1989 headlight
Yes, it will open on it's own power then close half way with in 5 minutes of driving...
Old Mar 19, 2006 | 09:45 AM
JETSET's Avatar
JETSET
Default try this
this is for an 87
http://automobiletest.com/service/19...ghts/index.htm
To 1989 Headlight problem
