Knock at start up
Old Jan 2, 2006 | 10:40 PM
larandy's Avatar
larandy
Default Knock at start up
'90 vert with 68k. At start up when engine is cold there is a knocking noise which seems to be coming from the engine compartment. The knocking noise only lasts for a minute or so and doesn't change with the rpms of the engine. The knocking noise is not discernible when the car is moving or at idle after initial start up. Any ideas would be appreciated. Thanks
Old Jan 3, 2006 | 12:48 AM
bogus's Avatar
bogus
I would think you are getting a little bit of slow oil... meaning, the engine is COLD and the oil takes a moment to get upto the top.
The only other thought... the fans. They come on when the engine is first started, then turn off. I wonder if you have a bad fan blower?
Old Jan 3, 2006 | 01:49 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would try some of this first ,could be just carbon build up.
http://www.bgprod.com
To Knock at start up
