Delco Pressure plate problem
Old Jan 3, 2006 | 07:19 PM
sonomacrew01's Avatar
sonomacrew01
Default Delco Pressure plate problem
I needed to replace my clutch so I found this on ebay.
clutch kit 93 corvette
The item describes that it will fit a 93 corvette VIN P or zr-1 VIN J. Which is part # 381068
PROBLEM: The two pressure plates have different #'s and mounting thicknesses.
old= 382109 OD
thickness with bolts
new= 382155 OD
I can't get the bolts to thread into the flywheel. Did I buy the wrong clutch kit?
Old Jan 4, 2006 | 05:03 PM
sonomacrew01
anyone?
Old Jan 4, 2006 | 05:21 PM
sonomacrew01
solved it myself. The thicker is for a ZR-1. I'm getting and even exchange for the correct one.
To Delco Pressure plate problem
