Rear ends.
Old Jan 3, 2006 | 11:46 PM
elmo89's Avatar
elmo89
8th Gear
Default Rear ends.
now that i got your attention, how hard is it to swap in a dana 44. i have the 36 with 2.59 gears and have came across a used 44. Can you get away with only the center portion or do you need the axels as well?
I already have the correct driveshaft.
thanks
Old Jan 3, 2006 | 11:49 PM
bogus's Avatar
bogus
you need the entire D44 assembly. The center will not bolt up to the D36 batwing.
I also think you need a different drive shaft, but I don't remember for sure.
Old Jan 3, 2006 | 11:54 PM
rightofway's Avatar
rightofway
so all you really need is the carrier, batwing and driveshaft?
Old Jan 4, 2006 | 12:02 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
To do it with the least amount of work,you will need the drive shaft from a stick shift and the C- Beam .3rd member and the bat wing.Axles,half-shafts are the same, the break cable for the emergency break may be different depending on the year and if you are replacing the whole thing,other wise just change the bat wing and 3 member drive shaft C-beam you are on the road.
Old Jan 4, 2006 | 06:12 AM
93 ragtop's Avatar
93 ragtop
And if you are thinking about poly bushings, exspecially the ones in the bat wing, now is the time to install, not when its back in the car.
Old Jan 4, 2006 | 08:39 AM
jispr's Avatar
jispr
Default 36 to 44
There is a great article posted here in Tech Tips. I will be doing the same change, already started, so maybe you could email me and help each other along. Done a lot of tool turning but this will be my first
transverse spring application. Jim Jispr@hotmail.com
Old Jan 4, 2006 | 08:30 PM
elmo89's Avatar
elmo89
8th Gear
I'll probably get started this weekend. wish me luck
To Rear ends.
