Setting LT1 valves on '95 cont.
Old Jan 4, 2006 | 08:12 PM
old motorhead's Avatar
old motorhead
Default Setting LT1 valves on '95 cont.
Looks to me like that the easiest way to turn the engine over when setting valves is with the starter. Not much room under there to get a wrench on the crank/balancer. What can I unhook or unplug to disable the ignition or fuel delivery? Plan to start the project tonite after UT finishes stomping the snot out of USC. Maybe over at half time. Help appreciated (even from a USC fan).
Old Jan 4, 2006 | 09:46 PM
JAKE's Avatar
JAKE
I use the stater to bump my engine when I adjust mine and never disconnect anything. Never had any problem doing that way.
Of course, you can pull the injector fuses if you want.
Jake
