307 Duration????
Old Jan 5, 2006 | 02:12 PM
95BlueBomber's Avatar
95BlueBomber
Default 307 Duration????
I am doing a head and cam package on my 95. The cam is .544/.576 112 and 307 duration. Is this way too much? It seems to me like it is a little to much duration. Anyone experience this before?
The Bomber
Old Jan 5, 2006 | 02:21 PM
CFI-EFI's Avatar
CFI-EFI
That sounds like an "advertised duration" or duration @ .006" lift, number. Not the common, "@ .050" lift, duration" numbers we most often use on here. It IS a healthy cam, but probably not as bad as you are initially thinking. Take a look at the ".050" numbers, and see if that doesn't look more familiar.
RACE ON!!!
Old Jan 5, 2006 | 07:40 PM
FD2BLK's Avatar
FD2BLK
What is the duration at .050? I have the CC 306 and the advertised duration is 290/307 with .510/.540 lift when using 1.5 rockers and can tell you it is a pretty stout cam. Are the lift #'s using 1.5 rockers? I think that is going to be a nasty cam for a stock ci motor and not have very good street manners at all. I think the most common mistake made is people going with to large of a cam shaft and in particular to much duration. A huge cam that makes a ton of HP is great for bragging but a PITA for the street if you loose all your low end TQ and will actually feel much slower 90% of the time then a smaller cam that makes gobs of low end TQ
To 307 Duration????
