LT1 Bracket installation help
Old Jan 7, 2006 | 01:46 PM
Fastmax32168's Avatar
Fastmax32168
Default LT1 Bracket installation help
Ok I know this is going to seem crystal clear once somebody tells me but for now I am stumped. I have got 1 bracket running from the back of the alt to the ex manifold and 1 running from the bottom side of the A/C to the exhaust manifold. Where does this one belong?
Roy
Old Jan 7, 2006 | 04:04 PM
Fastmax32168
Default Anybody have an idea?
Anyone please? I am sort of frozen in time with my final reassembly here because I am afraid I am going to have to take things back apart. I have to have missed this somewhere. Although it is difficult to tell in the pic this bracket is about 10" long and the two mounting holes are in a nearly parallel plane.
Roy
Old Jan 7, 2006 | 04:12 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
They both go the the manifold on the same bolt just to the left of the AIR tube.The 3rd bolt from the front.
Old Jan 7, 2006 | 04:14 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
It goes on the engine and exaust manifold .
Ok it connects to the exaust manifold with 3 rd bolt back with the bracket that goes to the outside of the A/C compressor.
This bracket with the crooked end goes on the bracket that holds the A/C compressor,on the inside of the compressor at the rear.
I'll try to take a pic.
Old Jan 7, 2006 | 04:32 PM
Fastmax32168
Default Thanks
OK cool I see it. Its hidden behind the A/C compressor. No biggie, I can pull that off in a minute. I was worried it went down below and attached to the P/S pump or something.
Roy
Old Jan 7, 2006 | 04:38 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Isn't there one that bolts to the rear of the accessory bracket and goes to another manifold bolt? I can't remember because I eliminated two of them due to headers but still have one.
Old Jan 7, 2006 | 04:40 PM
REDC4CORVETTE
Let me know!
Old Jan 7, 2006 | 04:55 PM
Corvette Kid
Okay, I looked at it and figured it out. The one I mentioned (and still have) bolts to acc. bracket just inside of the A/c compressor and goes to the 3rd bolt. Another one bolts onto the lower, rear compressor mounting bolt and also goes to the 3rd bolt. These are what REDC4 mentioned and has now showed pics of. Then there's one that goes between the alt. and it's rear bracket and installs at the 2nd manifold bolt. I think I needed more clarification than Fastmax!
Old Jan 7, 2006 | 05:48 PM
Redeasysport
Originally Posted by REDC4CORVETTE
Let me know!
Looks like you have a little overspray there.I cleaned mine up with a rag and brake cleaner.
Old Jan 7, 2006 | 06:40 PM
REDC4CORVETTE
That is first class Maui dirt,It's been 3 weeks since I cleaned under the hood .
Our dirt is red and they drag T shirts through it and charge the tourst 25.00 for a shirt they can't clean the red dirt out of.
To LT1 Bracket installation help
