the improved hooker y-pipe
Old Aug 4, 2001 | 03:49 PM
88sk's Avatar
88sk
Default the improved hooker y-pipe
just installed hooker# 2149, got the new&improved y- pipe& it DOESNT FIT,it doesnt clear shift linkage, had to use old y-pipe, but boy it sounds good, have to send back to summit&call hooker about y-pipe.. :cheers:
Old Aug 6, 2001 | 12:32 PM
Warlock's Avatar
Warlock
Default Re: the improved hooker y-pipe (88sk)
Mine BARELY fits on the manual. It is touching the pan for the od portion and will probably heat the fluid too much. if the actual "Y" was about 1/2" further back it would probably be perfect.
Old Aug 7, 2001 | 12:33 AM
88sk's Avatar
88sk
Default Re: the improved hooker y-pipe (Warlock)
doesnt seem they made any changes to the"new" design,expected to bolt right up after the header install, had all parts laid out&wham, had to cut stock y-pipe w/reducers (didnt have), thanx hooker.. :mad
To the improved hooker y-pipe
