VATS, Theft Deterent Module?
Old Jan 9, 2006 | 02:37 PM
VQT88Vette's Avatar
VQT88Vette
Default VATS, Theft Deterent Module?
I have narrow my VATS issue down to the module, its not the key tumpler or the resitor value of the key.
Has anyone bought a replacement VATS? Superior Chevy does not have it and Said that GM stop making it. Where can I find this module?
Old Jan 9, 2006 | 04:29 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you can't find one you may want to consider getting a new chip burned without the VATS. VATS is just another way to get stranded IMO.
Old Jan 10, 2006 | 01:02 AM
VQT88Vette's Avatar
VQT88Vette
Central,
Do you have any recommendation on whom in Southern CA?
Old Jan 10, 2006 | 01:42 AM
CentralCoaster
No, but i'll be looking for one soon too. I should just buy the stuff and burn my own.
I did some chip burning and assembly code in college a few years back.... I really have no excuse to not learn how on this prehistoric obd1 system.
Old Jan 10, 2006 | 01:57 AM
VtVette's Avatar
VtVette
Count me in too. I'm looking into a few ECU's right now with stock chips. First thing I want to do is get the VATS elimiated from the chip.
Let me know who you guys decide to go with.
Old Jan 10, 2006 | 03:12 AM
CorvAdel's Avatar
CorvAdel
I can speak on this subject as I have had it done. I had a vats issue and narrowed it down to the module too and was really worried about how to fire up my car after rebuilding the whole thing...car, engine etc. Since I had a few mods when I built my motor I needed a tune. I got tjwong to do it for me. He disabled vats, egr, air and a tune. He is up in Oregon and a real fair guy to deal with who seems to know his stuff. He is a CF member, and I have never heard anything but good reports about him...that's why I went there and have had no regrets.
Definitely an option worth considering...
Old Jan 10, 2006 | 03:30 AM
CentralCoaster
How much did he charge you? I'm not even needing a custom tune, just some vats/egr etc removal.
Old Jan 10, 2006 | 04:34 AM
CorvAdel's Avatar
CorvAdel
I got the lot...for $150....and since I am so far away (Australia), he sent me another chip with a slightly higher idle if I needed it at no extra. So from this I can only assume his price would be fair for vats disable only.
Old Jan 10, 2006 | 07:21 AM
kalister1's Avatar
kalister1
If you can find the wires for the resistor coming from the tumbler you can jumper a resistor into the connector to fool the VATS.
Old Jan 10, 2006 | 10:35 AM
rick lambert's Avatar
rick lambert
I understand why guys want to disenable the VATS-but essentially your vette becomes an easy theft target. I went with an after market alarm which bypassed the VATs-but still disenables the starter if an attempt is made to steal it. I love the keyless entry and same with the hatch, plus the other features-back up battery etc. other options which I did not have installed were auto start and window functions. It's been about 4 yrs since I had this done-with no problems.
Old Jan 10, 2006 | 10:54 AM
JAKE's Avatar
JAKE
A couple of the Vette mags sell plug in by-pass modules to allow you to disable the VATS. They plug into the existing VATS with no wire cutting. All you need is your ignition key code which'll be 1-15. An additional benefit is that a regular - non-pellet - key can then be used which saves of any key(s) you may want to get cut.
I had my key code read at my local ACE Hardward which can cut keys for my car. Your Chevy dealer can read it too, I had mine read for free at my local Chevy Parts counter.
One by-pass completely disables the VATS full-time and the other is switchable, allowing you to turn the VATS "On" and "Off" via a little toggle switch.
They're pretty inexpensive too. Mid-America sells the switchable model for $59.99 (part # 601-114) and the non-switchable by-pass (part # 601-116) for $24.99. I don't know what year you have, but the by-pass switch/module are listed for 86-89 Vettes.
I have an 86 but had mine turned off in the PROM.
Hope this helps
Jake
Old Jan 10, 2006 | 02:02 PM
VQT88Vette's Avatar
VQT88Vette
Any more suggestions?
I already have the after market alarm with remote starter. There are times that the key won't started the car but the remote does, then there are times that both can't start the car and left me stranded.
Old Jan 10, 2006 | 05:48 PM
CentralCoaster
The things that can disable the ignition are... park or clutch safety switch, TDM/VATS, or a bad ignition /column switch.
To VATS, Theft Deterent Module?
