Rear Spring
Old Jan 9, 2006 | 02:54 PM
ED HEISER's Avatar
ED HEISER
Default Rear Spring
I want to release my rear spring so I can remove it to get at the differential cover. I don't have a lift, just jack stands and two floor jacks and ramps. I have never played with a transverse spring before and don't know what to expect, or how to safely go about it. Any comments or photos would be appreciated as I can see my life flashing before me as something bad happens if I do it wrong.
Old Jan 9, 2006 | 05:54 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Once you've got it up on stands just use a floor jack to release the pressure on one side at a time and remove the end bolts. Use a block of wood between the jack and spring to protect it's delicate outer coating.
Old Jan 9, 2006 | 10:28 PM
Insane1's Avatar
Insane1
I just disconnected my rear spring on my car to remove the halfshafts to replace the u-joints/ I just took a short piece of 2x4 and put it on my jack and jaclet the spring up close to the bolt. There is a piece of metal there with a lip on it that I used to keep the 2x4 from slipping.
Old Jan 10, 2006 | 12:32 AM
rightofway's Avatar
rightofway
i just put a hockey puck on the jack and it worked fine with the jack coming in from the back
To Rear Spring
