Any trick to get out or just change an inst. cluster bulb.Blue Highlight bulb went out. does the cluster come out from the front or do I drop the bottm bolster and go in through there?
It's a 95'
To remove the guage cluster you will have to drop the steering column by removing the LH hush panel under the dash then remove the two nuts that hold the steering column. You can then remove the bezel and lens and remove the 6 bolts that hold the instrument cluster and pull it straight out.
The wireing is plugged in at the back so when you atr removing it it may feel like there is a hidden screw at the back left side but this is only the plug and will unplug with a little preassure.
I will be removing mine this weekend to install the white faced guages so if you have any problems just email me and I will give a more detailed instruction of each step and take some pictures for you
Good luck
Jerris
