Rear end ratio?
Old Jan 12, 2006 | 12:25 AM
old motorhead's Avatar
old motorhead
Default Rear end ratio?
Wife's '95 turns 1900 to 2000 rpm at 60mph. Has auto trans. What's the rear end ratio on her car? Thanks
Old Jan 12, 2006 | 12:35 AM
Perfusion's Avatar
Perfusion
There's a forum member named Nathan Plemmons (also his screen name). Send him a Private Message (or maybe he'll chime in here). He has an Excel spreadsheet that will calculate that stuff for you.
On a automatic '95, you've got two options, though - 2.45 or 3.07 (for the G92 performance axle option).
Old Jan 12, 2006 | 12:42 AM
ckd's Avatar
ckd
According to an online calc I found it says you have 2.54s but it could be wrong.
Old Jan 12, 2006 | 01:36 AM
DocSpeed's Avatar
DocSpeed
Me rear is equipped with a 2.59 gear. I think this ratio is more common and may be what you have.
vader86's Avatar
vader86
You have either 2.59 or 3.07 if its stock, the previous post wasnt exactly correct.
You can look in your RPO codes to determine what came with the car, look for any codes starting with the letter G and post them here. GM1, G44, G92, etc. are things youre looking for.
My car has 3.07s and runs 70mph at 2000rpm in OD. To me it sounds like someone has done something to your rear, but the tach isnt exact.
Old Jan 12, 2006 | 04:54 AM
ckd's Avatar
ckd
Sorry...dunno why I didn't catch that( regarding 2.54/59)...duh on my part.
Old Jan 12, 2006 | 06:42 AM
sonomacrew01's Avatar
sonomacrew01
raise the rear up, put the car in neutral and make a small mark on one of the tires and on the driveshaft. Watch how many rotations the driveshaft does for 1 full rotation of the wheel.
Or you could just reference with your RPO codes but who knows if someone before you had changed the gearing.
Old Jan 12, 2006 | 06:54 AM
Eike's Avatar
Eike
Default Excel spreadsheet
Hi,
I have an Excel spreadsheet, too.
Text is german, but I think it's helpfull ... Excel spreadsheet
Old Jan 12, 2006 | 07:19 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The original ratio is stamped on the rear. But the easiest way is to look at the RPO or do the tire spin method described above.
Old Jan 12, 2006 | 09:15 AM
rick lambert's Avatar
rick lambert
My 87 auto in OD with 3:07s runs around 1800 at 60-65, but I'm not all that sure of the accuracy with the digital tach.
Old Jan 12, 2006 | 09:54 AM
kalister1's Avatar
kalister1
I got this from the web site below.
http://www.nightrider.com/biketech/c...mulas_page.htm
Formulas for MPH RPM gears & tires
mph = (rpm x tire diameter) / (gear ratio x 336)
rpm = (mph x gear ratio x 336) / tire daimeter
gear ratio = (rpm x tire diameter) / (mph x 336)
tire diameter = (mph x gear ratio x 336) / rpm
Old Jan 12, 2006 | 09:58 AM
Strick's Avatar
Strick
It is stamped on the dif. (unless someone changed it). It will be hard to find unless you jack it up.
Old Jan 12, 2006 | 10:46 AM
Eike's Avatar
Eike
Old Jan 12, 2006 | 11:52 AM
GeosFun's Avatar
GeosFun
I have the 2.59 ratio and my car tachs at 1600-1700 at 65 to 70. So my guess is yours is 3.07. Be sure to jack up both rear wheels to do the wheel rotation method or your posi will make for a bad day. This is really pretty simple. For a 3.07 you should get almost exactly 3 driveline rotations for one wheel rotation. If the driveline mark comes around about a 1/3 to 1/4 turn less than 3 full revolutions, you probably gave the 2.59.
Old Jan 12, 2006 | 12:27 PM
Casethecorvetteman's Avatar
Casethecorvetteman
1900-2000rpm at 60mph isnt a stock ratio, id say thats around 3.31-3.33 or 3.45:1. 3.07 should see 1,800 at 60 mph as previously stated, and 2.59 will see around 1,550-1,600 at 60mph. Im led to believe 3.54 will be about 2,200 at 60mph.
Old Jan 12, 2006 | 03:39 PM
VenkmanP's Avatar
VenkmanP
If you have stock tire sizes it looks like you have 3.54
http://www.f-body.org/gears/
To Rear end ratio?
