COLDER 'cold air'
Old Jan 12, 2006 | 12:30 AM
smacko's Avatar
smacko
Default COLDER 'cold air'
After a discussion with a good mate; I added some heat resisting material (It wasn't TRUE heat shielding, rather noise absorbing material I had laying around with a thin layer of aluminium on it) UNDER the air intake housing of my '85; I just used the car and I SWEAR it's picked up extra 'gee-gees'!
The whole idea was to make the housing less prone to heat and heat-soak since the housing sits ABOVE a hot radiator housing...Seems to have worked!
Old Jan 12, 2006 | 08:59 AM
rick lambert's Avatar
rick lambert
It probably did. Anything keeping the intake cooler CAN add power.
Old Jan 12, 2006 | 07:33 PM
smacko's Avatar
smacko
Yeah I know but didn't expect results so quickly!
Old Jan 12, 2006 | 09:13 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Bidness op!!! Bidness op!!
You should be able to seel those for forty/fity bux including Corvette Tax.
Old Jan 12, 2006 | 09:25 PM
smacko's Avatar
smacko
hahaha...yeah, b4 ecklers etc makes them up as a 'kit'!
Old Jan 12, 2006 | 09:47 PM
LT4BUD's Avatar
LT4BUD
I have been contemplating the same thing after I realized how hot the intake gets and I did some data logging on the IAT....I have the SLP triple snorkle and was thinking about wrapping it with insulation/heat reflector of some sort..
Your report is real encouraging....I need to get busy..
Old Jan 12, 2006 | 09:53 PM
rick lambert
That's why guys think a 160 thermo is so great-supposedly adds HP-it doesn't-maybe the engine runs cooler-but it's the intake COOL air which causes it to perform better-you could and can pack your intake with dry ice or something else to keep the intake cooler which will cause the air to be cooler/colder and the engine to perform better!
Old Jan 12, 2006 | 11:06 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
smacko,
I think I'm in love..... with that hottie sitting on the white Vette.
Lawd, what a beautiful face....and all the rest tooooo. Woooooo!!!
Old Jan 12, 2006 | 11:10 PM
smacko's Avatar
smacko
smacko,
Yeah, she makes a good mascot for my car
Old Jan 12, 2006 | 11:13 PM
smacko's Avatar
smacko
Yeah but it's a PITA to keep sticking dry ice in there - much better to have an insulator
Old Jan 13, 2006 | 12:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
No matter what thermostat is used, the egine will eventually find the temperature it wants, just might take it longer to get there with a cooler thermostat.
As far as temperature/making hp there is a definite advantage to running cooler. JMO, not trying to bicker.
Old Jan 13, 2006 | 12:45 AM
rick lambert
Only a cooler intake-air, not engine!
To COLDER 'cold air'
