Roller rockers installed valves adjusted....
Old Jan 12, 2006 | 11:40 AM
old motorhead's Avatar
old motorhead
Default Roller rockers installed valves adjusted....
Otherwise stock LT1 in a '95 coupe.
Used the 3/4 turn past slack removed method on cold dead motor. Started it up and thought I could hear a lifter ticking. No oil splashing so I thought I'd leave it running and back off and retighten each one till I found the loose one. As expected they would all start ticking when I backed them off about 3/4 turn.
Now the part that I don't understand. I could only retighten about a quarter turn. Much more than that and the engine would run rough. I'm assuming that the valve was being held open by too tight of a setting. Setting the valves with the engine running took a setting that was a full half turn looser. If I adjusted back to the original cold setting, the engine probably woudn't run. What's up with that?
Old Jan 12, 2006 | 01:03 PM
Nathan Plemons's Avatar
Nathan Plemons
When you set the rockers originally you tightened them too far and depressed the plunger inside the lifter, either because there was no oil in the lifter or you pressed it all out. Once you started the engine and the lifters pumped back it began to hold the valve open instead.
Old Jan 12, 2006 | 01:34 PM
JAKE's Avatar
JAKE
That's normal. You have to re-tighten them a little at a time. Tighten a little, engine will stumble then clear up after several seconds. You then tighten a little more, etc., etc., until you finally get to the 3/4 turn you want to use.
Jake
To Roller rockers installed valves adjusted....
