Suspension
Old Jan 13, 2006 | 11:16 PM
96vetteLT4's Avatar
96vetteLT4
Default Suspension
What effect would replacing the stock rear spring with a Sport spring from Vette Brakes have on the handeling and performance of the vehicle with leaving the stock front spring in place? This is a 96 Lt4 with Fe1 suspension.
Old Jan 13, 2006 | 11:39 PM
96GS#007's Avatar
96GS#007
It'll make it loose. Of course this depends on things such as alignment and shocks as well.
Suspension really needs to be setup as a system, not piece-meal.
Old Jan 13, 2006 | 11:55 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I think you'd get better results upgrading the anti-roll bars. The standard springs are really plenty stiff for a street car. Another improvement that will really wake it up is the advanced street alignment specs. If you don't already have a maximum performance grade of tire, consider them next time.
Old Jan 14, 2006 | 12:59 AM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
I would not advise that. Changing out the front spring to a stiffer spring on the other hand without changing the rear spring will help. I run the stock 96 rear spring with an 1988 Z51 front spring that is almost twice as stiff as the stock 96 spring with very good results. I also have the 30mm front sway bar too. The car has been setup by Guldstrand Motorsports with a few other goodies, but they really know what they are doing when it comes to suspension.
Tha car is very neutral with this setup and wicked fast in the corners.
Just adding a rear spring will just make the rear end oversteer and break loose more.
C4 Spring rates
Old Jan 14, 2006 | 02:05 AM
Slalom4me's Avatar
Slalom4me
Edit (2006/01/18): Corrected conversion to 'force divided by distance'
This has changed the values.
VB&P have indicated to me that "the rear C-4 "Sport" springs can
range from 465#/inch to 540#/inch or higher" (81.5145 N/mm to 94.662 N/mm)
They mold their own, apparently.
You don't say whether yours is a coupe or 'vert '96 FE1. According
to the chart 'qwik96GS' refers you to, the front spring rates for the
cpe/vert are 60 N/mm & 73.2 N/mm (342.36 #/in & 417.6792 #/in)
So, if you have a coupe with the 60 N/mm (342 #/in) front spring and you get
a VB&P "Sport" rear spring rated at 540 #/in (94.662 N/mm, then you will need
to consider getting larger rear-view mirrors because IMO, this will result
in some oversteer.
For one of many on-line conversion tools, try this N/mm <-> lbs/in calculator
With this or something like it, you can review the other combinations
in the chart for a sense of what sort of fr/rr ratio the C4 has been built
with in the past.
Original post: Based on Torque units: NM <-> lb-in
range from 465#/inch to 540#/inch or higher" (52 NM to 61 NM)
cpe/vert are 60 NM & 73.2 NM (or 531 & 648 lb-in)
So, if you have a coupe with the 60 NM (531 lb-in) spring and you get
a VB&P "Sport" spring rated at 61 NM (540 lb-in), then you will need
in some oversteer.
For one of many on-line conversion tools, try these links NM > LB-IN
LB-IN > NM
with in the past.
Old Jan 14, 2006 | 10:54 PM
96vetteLT4's Avatar
96vetteLT4
Default Suspension
The reason I asked is that I am the 2nd owner of this vehicle. The rear suffers from a traction problem and is loose. The sport spring was on the vehicle when I got it and i'm trying to determine what spring is on the front. The rear is clearly marked with the Vette Brakess Sport spring but I can't find any markings on the front spring to tell if it is the stock spring or has been replaced. Anyone have any ideas on where to look for any indicators on the front spring to determine which spring it is? Thanx...
Old Jan 15, 2006 | 12:21 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Look for a two or three digit code (letters) stamped into the spring.
Old Jan 15, 2006 | 12:25 AM
Slalom4me's Avatar
Slalom4me
He can't find any markings.
Where is the code likely to be on the spring? Is there a reference
chart that can help decode any markings found?
Old Jan 16, 2006 | 04:04 PM
96vetteLT4's Avatar
96vetteLT4
Default Number
I did find this # stamped on the spring...10052233 -or 100522283-or 10052253...the next to last # is very hard to make out...any ideas on what spring it is..thanx...Gary
Old Jan 16, 2006 | 04:24 PM
96vetteLT4's Avatar
96vetteLT4
Default Spring markings
I also found H I 4 maybe this is it...thanx....Gary
To Suspension
