From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
101 Projects For Your 84-96 Corvette
In the above book, their's a mod. that moves the MAT sensor from the throdle boby extension to an area just behind the air filter & claims a few extra hp gain. someone on another forum claims that this mod. is worthless and in effect can actually cause a drop in hp. What are your thoughts an this? Can anyone substancuate the hp gain or loss.
You get better info here on the forum. I read most of it one night in Barnes and Noble waiting for my wife to finish shopping. I'm sure you married guys know how long a woman can shop. I will give him credit though, after a long explaination of most useless mods, he does tell you that they are basically useless. Fills up a book to sell I guess.
It's a trick to fool the computer into injecting slightly more fuel into the cylinders. This one works by sending a colder air signal to the computer than what the system is gauged to expect. I've also see gismos that change the resistance of a sensor to fool the computer into doing the same thing.
In general, I wouldn't do it myself for 2-3 hp. You don't gain this hp across the board and in all conditions. The computer uses a bunch of inputs to determine fuel flow under a bunch of conditions. At certain times, fooling the computer with an altered sensor signal will cause the system to pull out fuel and reduce hp, so you actual lose power.
There are lots of good things you can do to pick up power, but this is not one I would consider.
I remember the mis-info of this book that told me the LT4 had 4 valve heads. They also called the SEFI LT1 the LT2. Hopefully this is the same book I am talking about.
On the L98 that sensor is used for EGR temp. From what I read it doesn't do anything else for you. It couldn't help or hurt then yes? I moved mine because as I was porting the plenum, it looked to me like it stuck into the air flow. I'm doing all this air flow work and it's sticking up in there like a sky scraper! So it's moved.
Is this also known as the ambient air sensor? Got an extension to read outside air better because I live in a very hot climate. Running lean only makes engine run hotter. New at this and still don't have all these acronyms down. Doesn't MAP read air flow?
I'm not 100%, but I think you're wrong. The IAT sensor should affect timing. If I understand it correctly, it is set up to pull timing as intake air temp rises. Relocating the sensor prevents the computer from pulling timing due to an inflated air temp reading.
I know my car runs slower with heatsoak and even slower on hot days. I can't even break into the 8s in the 1/8th on a sticky humid day. This m0d is... plausible.
The reason I passed on it was because I did not want to have a set of wires running all the way to the front air box in plain sight, and for no noticeable gain in power.
Its about the same increase as the T/B bypass. 101 Projects was given to me when I purchased my 1996. The book takes procedures and condenses them into two paragraphs. The best way to handle this is to purchase a Helms Manual. www.helminc.com
