Rack going bad?
Old Jan 14, 2006 | 08:48 PM
kellsdad's Avatar
kellsdad
Default Rack going bad?
I've begun to notice free play in the steering wheel. The steering wheel and everything down to the steering rack will turn about half an inch at the steering wheel before the rack begins to move the steering rods. Does this sound like the rack is going bad? Is there an adjustment that can correct the problem?
P.S. The rack is from an 87 Corvette in a Cobra replica.
Old Jan 15, 2006 | 07:34 PM
MBDiagMan's Avatar
MBDiagMan
It's certainly POSSIBLE that the rack is getting loose, but that is not typically how they fail. I would expect to find the play either in a coupling between the steering wheel and the rack input shaft OR in the tie rod ends.
It's time to do the 4 P's. Push, Pull, Pry and Prod. Start wiggling and shaking everything until you find the culprit.
Good luck,
Old Jan 15, 2006 | 08:56 PM
kellsdad's Avatar
kellsdad
Thanks for the comments. This is my track car so I'm pretty cautious about anything regarding steering or brakes. I figure this is the original 20 year old rack from the donor car used to build this Cobra, so I've decided to replace it just for peace of mind.
Old Jan 15, 2006 | 11:48 PM
thomastl's Avatar
thomastl
I have the same problem. Input shaft turns w/ the steering wheel but there is about 5 to 10 degrees or so of slop back and forth. The output does not move w/ this slop.
Let us know if swapping the rack fixes it.
Old Jan 22, 2006 | 07:09 PM
kellsdad's Avatar
kellsdad
OK. The rebuilt rack is in and it did eliminate the free play in the steering. While preparing to install the new rack I discovered there is an adjustment that might have helped the old rack. I didn't try it so I don't know what effect it would have had. ... One item of information I needed but couldn't find elsewhere regards the tie rods. In order to adjust the toe in I had to rotate the tie rod to move the tie rod end in or out. There are no flat surfaces on the rod for a wrench to make it clear it is supposed to be turned. Ultimately, I grabbed the rod with my ViceGrips and it turned easily.
Old Feb 1, 2006 | 10:43 PM
thomastl's Avatar
thomastl
What adjustment are you talking about? I have not done anything w/ mine. Would definetly like to try an adjustment of some kind.
To Rack going bad?
