LT1 Low idle when cold
Old Jan 15, 2006 | 05:37 PM
BlackbirdZ07's Avatar
BlackbirdZ07
Default LT1 Low idle when cold
This used to be an intermittent problem so I didn't worry about it, but now it does it all the time. When I first start my '92 LT1 six speed, the idle is very low (200 RPM) unless I open the throttle. Sometimes the engine will die. However, after driving the car for a bit it the idle seems to be almost normal, although it may still be just a little low.
I had the throttle body apart and cleaned out the IAC pintle and bore about a year (5,000 miles) ago, so I don't think it's dirty. Also the fact that it started as an intermittent problem suggests some electical problem.
I plan to replace the IAC motor, but I just wanted to see if anyone has any other suggestions first. Thanks!!
Old Jan 15, 2006 | 05:40 PM
bogus's Avatar
bogus
Replace the IAC first...
Old Jan 15, 2006 | 06:47 PM
ittlfly's Avatar
ittlfly
When you R&R'ed your IAC, did you check the pintal extension for the proper distance? Shooting from the hip here, it is something like 1-1/8"
Old Jan 16, 2006 | 02:30 PM
BlackbirdZ07
When I took it apart I was careful not to change the adjustment, but I did not check it. I thought that was something that was adjusted automatically by the ECM.
I'll probably replace the IAC, but I'll check that distance when I take it apart. Anyway, it started and idled just fine this morning, so it's definitely an intermittent problem.
THANKS for the help!!
Old Jan 16, 2006 | 04:17 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I know this may be reaching but I recently had the same problem. I fixed the problem by mistake actually since I was trying to get the car to pass emissions for my State Inspection. I changed the sparkplugs andlow and behold the car runs like a new car. No more idle problems and it runs great!! I know some like to run the AC Delco plugs but I put in some NGK-TR55s and damn this car seems totally different. The TR-55s are the copper plugs in contrast to the Iridium versions. I have heard that the copper ones produce a better spark. I had a spare set for my C5 and put them in the C4 and like I said, the car runs great!! This may be an option to check. Goodluck in your search.
Old Jan 16, 2006 | 06:22 PM
ittlfly's Avatar
ittlfly
Intermittents are a bi**h sometimes. It might help to hook up a scanner on start up and monitor the IAC.
Old Jan 16, 2006 | 08:29 PM
SunCr's Avatar
SunCr
May not be the IAC at all - check the Coolant Temp Signal (you'll need a scanner). If the ECM thinks the engine is warmed up, there won't be any fast idle.
Old Jan 16, 2006 | 09:40 PM
SunCr's Avatar
SunCr
PS: Make sure the a/c is off - if the fan(s) are running - the ECM thinks it's at least 217 (if I remember the threshold for the '92 correctly). Troubleshoot the CTS accordingly.
Old Jan 17, 2006 | 08:27 AM
ittlfly's Avatar
ittlfly
The threshold for the 92 is 226-228 for the primary fan. I agree with SunCr that a malfunctioning CTS (coolant temp. sensor) will cause the same symptoms.
Old Jan 17, 2006 | 12:39 PM
BlackbirdZ07
I have an EASE computer based diagnostic tool that I bought on the forum a while back that I've never used. I'll have to try to get it going and check the CTS.
I know there are actually two coolant temp sensors, one for the digital gage and one for the analog. Which one does the ECM use? I assume the one for the digital display.
If that CTS is faulty, wouldn't I be getting a faulty reading on the digital temperature readout?
Thanks again!
Old Jan 17, 2006 | 01:37 PM
ittlfly's Avatar
ittlfly
Thanks again!
The ECM uses the CTS mounted on the front of the water pump for the digital read out and other functions. You might also monitor the IAC too if your car starts acting up.
Old Jan 17, 2006 | 03:19 PM
Jet-Jock's Avatar
Jet-Jock
When you started up the engine after R&R'ing the throttle body and IAC, did you set the idle electronically. That is on the first start, press and hold the accelerator pedal and start the engine. Let it run for 2 seconds then off. Restart and let it idle.
Old Jan 17, 2006 | 03:41 PM
Nathan Plemons's Avatar
Nathan Plemons
FWIW once the IAC has been run on the car they specifically tell you NOT to mess with it by hand because you can break it. I'm not sure if it's some kind of worm gear that just isn't engaged until first year or what.
Old Jan 17, 2006 | 07:32 PM
BlackbirdZ07
I don't remember but I don't think so. I seem to remember that procedure was for a new TPS. That was more than a year ago and it's been fine until recently, so I don't think the problem was caused by anything I did back then.
Old Jan 17, 2006 | 07:33 PM
BlackbirdZ07
That's why I cleaned it very gently and didn't mess with the adjustment at all.
Old Jan 17, 2006 | 08:14 PM
Jet-Jock's Avatar
Jet-Jock
TPS requires connecting a Tech 1 and running the learn idle program. I mis-stated earlier it's learn throttle position on the IAC start sequence. Procedure is still applicable, but after this much time I can't say whether it will do any good. I believe it performs a step count to set the IAC.
Generally just spraying the pintel end with throttle body cleaner is good enough.
Adjustments are only recommended for new IAC's, prior to installing you take a specific measurement and if it's greater you gently press.
Old Jan 17, 2006 | 10:17 PM
corvette1989bham's Avatar
corvette1989bham
I believe that on the LT1 there are TWO coolant temp sensors, the one on the water pump is for your gauges and the one on the engine is for your ecm. If you check the readout on the CCM you get the same data the ecm is reading.
To LT1 Low idle when cold
Old Jan 17, 2006 | 10:25 PM
SunCr's Avatar
SunCr
Unless the ECM is broken - CTS, wiring and your digital may be fine; that's why you need to scan it.
Old Jan 18, 2006 | 03:15 PM
ittlfly's Avatar
ittlfly
On the LT1, it'a just the reverse. The one on the right head is for the analog guage while the ECM uses the CTS on the water pump for digital and A/F.
Old Jan 18, 2006 | 08:29 PM
corvette1989bham
Thanks for the correction, I always get those confused!
