I need to replace a failing U joint on the left rear halfshaft. The shop manual refers to a leaf spring compressor. I could not find a reference to this on any of the other threads here on lowering the car, swapping springs, etc. Is this part needed, or is there a better way to do this? I'll need to swing out the rear wheel/hub/bearing carrier to remove the halfshaft, and the spring needs to be disconnect to do this...Any ideas?
I used a bottle jack to put pressure on spring - vice-grip on long stud & take nut off (mark or measure where the nut is on the bolt). Not much of a problem if you are only taking one side off.
Do a search - you do not have to take that much off to pop the half shaft out.
I have dropped the rear spring with a floor jack just fine.
tension the rear spring at the very end, or, just inboard of the bolt, just enough to release the bolt. then, remove the bolt and lower the jack. Done. Repeat for the other side.
This is very easy and VERY SAFE.
This procedure is easier than it looks! I use a block of wood on top of the jack and I lift the spring on the metal spring end plate.
When I did mine, I didn't do any of the above. I just loosened the nut on the long bolt and when the nut got near the end of the bolt, the tension was off if the nut. The bolt is long enough, on my car, to release the spring tension
RACE ON!!!
What he said. I just did the ujoint/ halfshaft drill. No need to compress spring.
RACE ON!!!
...depending on the spring preload. The actual I have on my car is with a "unloaded shape" similar to a reversed U.
even with very long bolts there is a so much preload ... Ask to my friend when the end of the spring slammed directly on his hand... He was luky and reported only a minimal problem on the hand...
The spring I'm installing now (a Vettebrake one) is pretty orizonthal.
-Beppe-
RACE ON!!!
I think I could do mine that way with the shocks disconnected.
But, with the shocks in place, I don't see mine being done that way.
My shocks were connected. I was doing the half shaft u joints. Also, I disconnected the camber rods at the knuckle, so that I wouldn't have to mark, and hope and pray, that I was able to accurately duplicate the camber adjustment.
