113 heads
Old Jan 16, 2006 | 03:04 PM
zapc's Avatar
zapc
Default 113 heads
swapping 113 heads into an 87 vert, will all stock parts work?
intake and exhaust manifolds especially.
Old Jan 16, 2006 | 03:40 PM
Vic'89's Avatar
Vic'89
Yes, they should fit with no issues. The 113 heads are Corvette heads.
Vic
Old Jan 16, 2006 | 04:41 PM
flatlne's Avatar
flatlne
Vic
Old Jan 16, 2006 | 05:05 PM
zapc's Avatar
zapc
when they refer to d port, isn't that the exhaust port, so i assumed it would need a d port exhaust manifold to line up
Old Jan 16, 2006 | 05:19 PM
vader86's Avatar
vader86
Yes its the exhaust port, but there was no change in the exhaust manifolds.
Old Jan 16, 2006 | 06:27 PM
zapc's Avatar
zapc
you guys are the best
Old Jan 17, 2006 | 09:08 AM
M Nordin's Avatar
M Nordin
7th Gear
I put on 113 heads on my L83 (1984). Gross mismatch between manifolds and ports.
BR
MN
Old Jan 17, 2006 | 10:26 AM
scorp508's Avatar
scorp508
Yes, but now you're comparing two different engines.
Old Jan 17, 2006 | 12:45 PM
zapc's Avatar
zapc
still a little suprised that the exhaust manifolds are the same from the 2 different heads, I'm sure that there are other differences in the heads but why would the 87 manifolds have a d port flange, if the 87 heads are not d port
To 113 heads
