Big Problems
Old Jan 16, 2006 | 05:05 PM
94ragtop's Avatar
94ragtop
4th Gear
Default Big Problems
I was backing up in a busy parking lot buy myself, stopped coudn't see any cars in front of me so I was going foward and (not on purpose) jumped the front of the car onto a tall parking lot curb, I get out and looked underneath. the car is literaly high centered (curb is right up at the factory cats) My back tires still had traction. So this is what I did, probably not the best but I put in reverse and scrapped the car off the curb backwards ooouch!!! My father says I broke a motor mount makes sense to me, Becuase now when I drive the car at low speeds low rpm coasting it runs fine and smooth. When I get on it any time gun it I hear and feel a vibration like parts underneath grinding or shaking (even when car is neutral and I give it gas) No b.s. Could this really be a motor mount problem?
1994 roadster, LT1, Auto, all stock, 78k
Old Jan 16, 2006 | 05:20 PM
hz900's Avatar
hz900
The only way I see you finding out for sure is to put the car on jackstands and get up under it and check it out. I would say its also possible that you bent up the flywheel dust cover. Its pretty flimsy, although I've done that before and it made noise at all rpm levels.
Old Jan 16, 2006 | 05:38 PM
rick lambert's Avatar
rick lambert
Yeah, you need to get underneath it-the tranny pan is pretty low too-if it's auto. Good Luck.
Old Jan 16, 2006 | 06:12 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Look at it this way.
A motor mount or a pan is easy to replace than a frame.
Best of luck.
To Big Problems
