Mini Ram Questions
That being said, the Mini Ram is generally regarded as a somewhat higher RPM intake. With a mild cam (as you mentioned above), I don't think you will be able to take full advantage of the Mini Ram's upper RPM capabilities. The Super Ram would probably be an ideal intake for your set up. There are pros and cons to both, as you will soon read about...
This is with a 396 stroker heads/cam/headers etc and mild tune
no times cause no time
Alan
Do you have flow #s from those heads?
P.S. Not to poop on your parade I don't think with that cam, ported intake and ported heads you are at 375chp. Probably closer to 335-340, unless your heads are really flowing some big numbers.
As far as feeling stronger, I suspect it does feel stonger than a 2000 z or 2002 vette down below 4000 rpms but after 4500 I'd bet that the vette or z would pull away from you.
These 2 dyno runs are the same motor. The lower hp is a bigmouth intake and the higher number is a Miniram. The only other difference is a hi flow cat convert with the Miniram. This motor has a set of Trickflows and a 219.
I didn't get to the dyno after I changed just the cat, but thru qtr mile mph I figured a 18 hp gain which would be around 15hp at the wheels.
The math I use is 20% loss for an auto and 15% for a stick. Since I am an auto I put my car before the intake change at 364 chp. This is based on my estimate of 292 rwhp due to the cat change up from the 277rwhp that the dyno sheet shows.
Since I'd guess my heads flow better than yours, my cam is a bit bigger and I don't think a ported stock intake will flow better than my bigmouth/tube setup that is what I am basing my 335/340chp number on.
There is some more left in this setup come spring with another exhaust change.
what a difference. can u post the diff in the torque as well?
Not from that graph.
Also, the big low end difference is due to the torque converter being unlocked and flashing better low end torque for the Bigmouth pull. I locked the convertor for that particular Miniram run. Had I left it unlocked it lost a lot less on the low end than this particular dyno sheet shows.
Here's a couple gtech runs. The first one is the Bigmouth and the second is the Miniram. Notice how the bigmouth closes in at the 60mph mark but the mini starts to pull away as the speed increases.
And for the gtech haters, I ran a 12.58 at the track, pretty damn close to that 12.52.
The mph reads high but it seems pretty close in the ET department.
Run 3 was when the car was stock with a catback and pulleys.
