Paper Clip Diagnostics
Old Jan 17, 2006 | 03:21 PM
YorkL8apex's Avatar
YorkL8apex
Default Paper Clip Diagnostics
I've seen the procedure and codes listed here before but a search and look through the sticky's did not find them. Anyone have a link or that can post the jumper procedure and the code listing for a 91 C4.
I have them at home but have someone asking for them today.
Old Jan 17, 2006 | 03:44 PM
pablocruise's Avatar
pablocruise
The two upper right terminals are A and B. Jumper those two and turn the key to on but don't crank the engine. The fan should come one and after 3 cycles of "blink...blink, blink" <----code 12
any stored codes will blink out 3 times each. Example:
Code 33
blink,blink,blink.....(pause) blink,blink,blink
next code and so on.
When all codes finish(from smallest number to biggest)
it will return back to code 12.
Old Jan 17, 2006 | 04:18 PM
JAKE's Avatar
JAKE
Someone may had a link to a site that has all the codes listed and hopefully will post it for you. Posting each code and the associated cause and cure on this site calls for a LOT of typing.
If no one posts a link, it would be a LOT easier for you to pull any stored code(s), then post it here. We can then post what you need to know to address the problem.
Another option is buying a Haynes manual for your year. About $20 at many of the auto parts stores.
Jake
Old Jan 17, 2006 | 04:30 PM
YorkL8apex's Avatar
YorkL8apex
Thanks, there was a link with all the codes posted at one time but I can't find it. I'll bring in my Service manual and scan the pages tomorrow.
Can't believe I have not written this up and stored it some place. Folks ask about it all the time.
Tony
Old Jan 17, 2006 | 06:50 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I tried to use the GM tool to diagnose my 95. It worked fine for my 92 but it does not even fit in my 95. Help......
Old Jan 18, 2006 | 12:56 PM
Red Dwarf's Avatar
Red Dwarf
For your 95 Ground pins #12 to #4. It will display codes on the speedo. There was a site c4vettes.com that had a very explanation for pulling codes, etc. Can't find it as of late.
Old Jan 19, 2006 | 12:01 AM
MrRenoman's Avatar
MrRenoman
I just pulled this off the net...
http://www.corvettecluboftexas.org/d..._ECM_Codes.doc
To Paper Clip Diagnostics
