Chassis bushings
Old Jan 18, 2006 | 03:22 PM
Snuffy's Avatar
Snuffy
Default Chassis bushings
I've read a number of threads about replacing chassis busshings. How do you know they need to be replaced? Any particular noises or handling problems? Do they crack or fall out?
Old Jan 18, 2006 | 03:32 PM
Nathan Plemons's Avatar
Nathan Plemons
The bushings likely won't fall out, but you can just look at them. See if they're particularly hard, or worn looking. A good example is the rear spring bushing, it gets flattened eventually to nearly nothing.
If your car has a lot of miles on it, it wouldn't hurt to replace the bushings.
Old Jan 18, 2006 | 11:16 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Also look to see if oil has gotten on any of the bushings - particularly the ones directly under the diff. Oil seems to deteriorate the stock bushings really quickly. This is why I had to replace mine with Energy Suspension poly bushings.
To Chassis bushings
