AUUGGH! yet another issue
Old Jan 19, 2006 | 04:28 PM
94azvette's Avatar
94azvette
Default AUUGGH! yet another issue
Ok so today I start my 94 c4 and the service ride control light stays on
first it was the LTPWS light which, and you all were great with the advice on that issue, next my driver window motor went out and once again you were great with the advice. So now that I have this thrid issue I was hopeing you could let me know how serious it is and what i should do. Thanks!
Old Jan 19, 2006 | 04:45 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Did I miss something????
What's the third issue ???????
Old Jan 19, 2006 | 04:49 PM
94azvette's Avatar
94azvette
my service ride control light is on and i have no clue what needs to be looked at and I wanted some advice before i take it to a shop
Old Jan 19, 2006 | 04:51 PM
cosmicvette's Avatar
cosmicvette
Is service ride control an Fx3 issue? (do you have fx3?) so, does that mean its an actuator not working correctly?
Im sure someone will chime in soon
Old Jan 19, 2006 | 06:36 PM
prattman's Avatar
prattman
94azvette,
If you have a service ride control light on, you have the FX3 option. There is a small motor (Acuatorts) on top of each of your shocks, I have the same on my 94.
The experience I have had so far is 2 of the actuators have gone bad, one of them had a small gear break inside, and the other was the small metal gear on top of the shock broke.
I found them on ebay, had to pay $100.00 for each one and they were used.
The are very expensive new, and hard to find, but my advive is to pull the code and see which is causing the problem. You can then swap it with the one on the opposite side of the vehicle, let it set a code again, and then pull the code. This will tell you if the actuator is causing the problem. Be careful about taking it to someone as my experience has been that most folks will have you replacing parts that are expensive, like the control module. (Don't ask me how I know this.)
prattman
Old Jan 19, 2006 | 06:57 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Damn man. Don't panic.
Did you cycle the car over 3 times with out moving it?
Get a paper clip and go through the code retrieval process and identify which one is the culprit.
To AUUGGH! yet another issue
