When do I need a 58mm throttle body?
I have a AS&M 58mm throttle body.
If I install this now will I hurt performance?
Can I benefit from the larger throttle body if I use LT headers?
Should I save this for when I do the heads?
All opinions are appreciated!
Jim
[Modified by jimbjr, 9:56 AM 8/6/2001]
Jim
I don't know if it will hurt performance (I have heard others say iot will), but it will not help unless the rest of your intake already flows better than your current throttle body. Only if it is the restriction will it give you better performance. Your hp without Nitrous is not that massive and it won't help the nitrous, so my guess is it wont help you. Running a 383 SR, I wouldnt need a 58 due to the MAF restriction in my intake. No matter what, it will restrict my airflow more than a 52mm throttle body. Thats one of the reasons I am switching to a speed density setup and custom ram air intake. With that setup, I will be running a 58mm.
When Tom Keliher's car was used in a GMHTP article, they swapped the stock (or was it a 52mm??) throttle body for the 58mm and the car slowed down. This was on a 13 second car. The 48mm throttle body on the TPI cars is capable of flowing over 750 dry cfm, which is more than any mild motor needs. I can't imagine an LT1 having substantially different air requirements.
[Modified by Jim85IROC, 3:58 PM 8/6/2001]
Considering the following I would say never.
1. GMs RamJet 502 makes 510 HP on a 48mm TB
2. A 383 at 6500 rpm and 100 %VE needs 720 cfm and stock is worth 750 cfm.
Larger TBs also reduce driveability because the accelerator pump shot in the computer program is set up for the smaller stock TB. A larger throttle body will require more fuel when the the throttle plates are opened.
I found the part throttle response on my stock 350 was much much better after I put the stock TB back on.
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Cartek used a 52mm TB on my new package and it's working fine with my ported heads and intake. I would not go any bigger till you go to aftermarket heads.
Mackey, have you tried a 58mm TB? It would be interesting to get some data to back the claims that the 58mm TB will not help. I think we all can agree that most of what we read in magazines is BS! If you know anyone that has had a car in there and know the car, you will always get a big laugh readaing what they say!!!
I would think if you got a larger throttle body you would also need a larger maf sensor. But I don't see how increasing the size of the throttle body (more air in) could hurt performance if the exhaust was unrestrictive (more air out). Maybe your timing is too retarded.
I have to know by Wednesday if I am going to install this throttle body or not.
Is there anyone who thinks this will help performance on a stock motor. :confused:
If not I guess I will wait to do more engine work before I install it or sell it.
Jim
[Modified by jimbjr, 4:39 PM 8/7/2001]
Jim
Chris, if Julio at Cartek saids a 58mm is to big for my set up than it's to big.
Julio knowes what works and I trust him.
John
You do not want to use larger than a 52mm tb on 350(or less) cubic inches.
Air velocity it the key. You will lose it with a 58mm TB on your setup. Here is a Q&A from the FAQ section of http://www.tpis.com. It sums it up well...
Q: I have a 1989 Camaro with a 5.7. I am looking into purchasing a throttle body from you and was wondering if a 58mm would be the best choice. I have headers, ZZ9 cam, exhaust system, under drive pulleys, and a 3.73 gear.
A: The 58mm is too big for this set up, you would go slower with the 58mm. I would recommend our 52mm throttle body, you will be more satisfied. The problem with the 58mm is it's too big for a 350ci motor, the velocity of the air will slow down resulting in poor low end power. Unless you have a supercharger or a 383ci motor or bigger, the 52mm is the better choice.
:cheers:
:cheers:
I agree with 90Callaway, from my numerous racing buddies and trips to the track, I wouldn't go with a 58mm unless you were running a 383 or a supercharger. And even with the supercharger I understand a 58mm is questionable.
Looks like I made an emotional and bad purchase. It looks so nice though.
I will probably try and sell it.
Thank you for the input.
Jim
[Modified by jimbjr, 8:26 AM 8/8/2001]
Jim
I dont think you would need it. Mine has the 52 MM. Im pretty sure that if it was advantageous they would have put a 58 MM in during the conversion. And my car speaks for itself !! :D
Rich
Rich
This is a low RPM motor, unlike the LT1 in modified form. There are different air requirements for this. I sure wish someone would put up some dyno or track proof instead of opinions and guesses?!?! I have seen a 58mm TB pick up HP on a dyno, but I do not have a copy of the dyno sheet as it was not my car and at a dyno day. Oh Well. :(
Here's a pretty good read with dyno results and all comparing a 58 to a 52mm Throttle body. I've always said that 48 is all you need for 475 or so but this testing is screwing with my thoughts.
This was probably a 450-460 Horsepower engine and it looks to have benefitted from the 58. It's almost one of those "It couldn't hurt" kinda deals. I didn't notice that your car was not an LT1. I've sort of got them on the brain right now and thought that everyone had one.
Bottom line for me is you wouldn't need one unless you had good flowing heads, headers, compression and everything working together.
02-28-2010, 09:05 PM
ASM 58mm vs Stock Bored 52mm Throttle body
Article by Leon Hartsock (ZDriver96)
February 20, 2010
http://i712.photobucket.com/albums/w...96/Camaro1.jpg
When I set out on this project I really didn’t know what to expect. On one side individuals were stating that the 58mm throttle body was not needed for an engine putting down around 400 rwhp. On the other side proponents stated that they felt the 58mm throttle body gained them power. But nowhere was I able to find back to back tests comparing the two. GM High Tech ran an article on this years ago called, "LT1 Aluminum Rocker Arms and 58mm Throttle Body Upgrade". This article included a 52mm vs 58mm throttle body test but compared them against each other with different intake manifolds. So I figured it was time to settle this age old question once in for all. I was not interested in hearsay, not interested in track results done on different days in different weather, not interested in what a mathematical formula stated, and not interested in whether your girlfriend was on Team Jacob or Team Edward. Why am I not interested in these? Because none of these definitively show if power is gained with a throttle body modification. In my comparison the only variables will be the Throttle body’s themselves and the slight change in outside temperature as the day warmed. This would ensure consistency and a true measurement of just how much, if any, power is gained through the addition of a 58mm over a 52mm throttle body.
The ASM 58mm Throttle body:
There are many different companies that design and sell throttle bodies. I wanted the best of the 58mm throttle body’s out there. I did not have to look far. I gave Jim Shofner a call at Arizona Speed & Marine and spoke with him about his throttle bodies for my built LT1 application. I could tell he was very knowledgeable on his products and he took the time to answer all my questions. Upon receiving the 58mm ASM it was clear that this was a quality piece. But would it install easily? More importantly would it perform as good as it looks?
http://i712.photobucket.com/albums/w...8frontaspx.jpg
The 58mm ASM came with all hardware and gaskets to replace the OEM. Both the IAC and the TPS sensor fit in smooth. The throttle cables snapped in nicely. The install was seamless.
The competition:
Sitting to the left is the OEM throttle body, which was ported to 52mm and an added airfoil. Sitting on the right is the 58mm ASM throttle body.
http://i712.photobucket.com/albums/w...ebysideNEW.jpg
The ASM 58mm is weighs less than the stock throttle body. The ASM also eliminated the TB coolant connections found on the stock throttle body. The throttle cable connection is made out of a hard plastic vs the metal construction on the stocker. The IAC also seems to respond differently to the ASM as it likes to hold the idle a couple hundred rpm’s higher while your car is neutral but still moving. This might be a tuning issue but when the 52mm is installed it idles lower while the car is moving. But when the car comes to a complete stop the idle returns to the 900 rpm range which is what the computer is tuned for.
STRESS RELIEF:
Vital to any modification or parts installation is the speed bag. If only I had this piece of equipment the first time I saw that GM engineers, in all there wisdom, deemed it necessary to have the water pump weep hole directly over a non-water resistant, o-ring cover lacking, sensitive electronic optispark. Notice the big screwdriver and duct tape also vital to f-body maintenance
http://i712.photobucket.com/albums/w...dbagandCar.jpg
Preceding the Testing Process:
Prior to this throttle body project ever starting, my 1996 Z28 Camaro underwent an extensive make over. This Camaro has a 11.1:1 355 engine with LE2 heads and matching LE2.3 camshaft. Every single mechanical piece in the Long block is new. The T56 six-speed transmission has less than 15,000 thousand miles and the clutch has less than 5 thousand. Jeremy Formato from Faster Proms performed dyno tuning. Jeremy spent a couple hours dialing the timing and air/fuel ratio with the 52mm. He kept the fuel purposely slightly on the rich side to leave room for a 58mm, which did not affect power gains when using the 52mm throttle body. I’ve known Jeremy for a long time and knows he does great tuning.
Getting a feel for the 58mm Throttle Body:
I drove the car a good 100 miles prior to brining the Camaro to the dyno. As expected the throttle response had increased. I was not subjected to the throttle ever sticking. I could not feel any power difference in WOT runs but then again the gains could be small and not really noticeable. Only thing I did notice was the rpm’s staying up a little higher while putting the car in neutral and coasting. When the car stopped the revs would drop to idle. Datamaster logs also showed everything operating normally with left and right fuel banks fluctuating between 126 and 138.
58mm vs 52mm Show down Results!:
The guys over at Proven Performance let use their dyno for my comparison project. Not only were very professional and knowledgeable but they had inexpensive costs on labor and dynometer usage. Unfortunately the car was run to 5700rpms (red line) for the first couple runs without me catching it. I only had a limited amount of time on the dyno and wanted to keep things consistent so we just measured the power gain up to 5700 rpms. The runs afterward to 6500 rpms showed the power continue to increase into the 6200 rpm range just like 52mm. But these subsequent runs had slightly lower power results because the engine was running hotter. Fan settings set at 180 degrees with a 160 degree thermostat. Temperature gauge stays at about 170 degrees. When the 52mm was tested the engine had 15 minutes to cool down.
http://i712.photobucket.com/albums/w...s525700rpm.jpg
At certain rpms the torque gain of the 58mm was up to 20 ft lbs higher than the 52mm. Horsepower gains are most noticeable in the upper rpms where the engine is utilizing the additional airflow.
Its important to remember that this test is simply comparing the 58 vs the 52.mm throttle body. This is not an accurate reflection of an LE2 setup because I have a plate covering 70% of my right exhaust causing the car to lose a fair amount of horsepower in an effort to lower the exhaust noise level.
This graph shows the wide band O2 reading. You can see that 58mm provided more air thereby leaning out the air to fuel ratio. If it leaned out the mixture its telling me that the engine did make use of the additional cfm.
http://i712.photobucket.com/albums/w...rfuelgraph.jpg
This graph shows the temperature and humidity difference between the 58mm and 52mm runs. It was 6 degrees cooler and 9% more humid when the 58mm was run.
http://i712.photobucket.com/albums/w...conditions.jpg
Conclusion:
Well the graphs speak for themselves. It can be argued that the temperature change and tuning could have resulted in the gains. But I doubt a 6 degree temperature change will net you peak 7rwhp and mid range 20ft lbs of torque. The tune was actually meant for the 52mm. We richened up the tune and got the same horsepower and torque as when it was leaner to accommodate the future 58mm. When dyno tuning the 52mm weeks prior to this comparison the Camaro put down 389rwhp. The 9rwhp increase was due to temperatures being in the mid-upper 50’s. At 76 degrees the 52mm put down 380rwhp. 9rwhp difference needs approximately 20 degrees.
I would think this test is applicable to anyone considering a 58mm throttle body for a vehicle putting down close to or over 400rwhp
February 20, 2010
The competition:
STRESS RELIEF:
Conclusion:
