how do i tell what diff i have?
Old Jan 19, 2006 | 09:05 PM
89vettefromhell's Avatar
89vettefromhell
Default how do i tell what diff i have?
is there a way to tell what differential is in the car... did they only make D36s on 90 and belows?? or did the early L98 C4s come with D44s at all??? i wanna figure out so i can get some new gears
Old Jan 19, 2006 | 09:12 PM
vader86's Avatar
vader86
All manuals 85-96 are D44
Everything else is D36.
Old Jan 19, 2006 | 09:15 PM
89vettefromhell
ahh ok now i know that i have a D44 ty ty!!!!
Old Jan 19, 2006 | 09:18 PM
89vettefromhell
now will gear sets from any D44 work right in mine??? like say.. 3.73s from a 4wd Jeep?
Old Jan 19, 2006 | 09:19 PM
89vettefromhell
does teethcout/splines matter?
Old Jan 19, 2006 | 09:58 PM
89vettefromhell
ttt
Old Jan 19, 2006 | 10:06 PM
Pete K's Avatar
Pete K
Your car absolutely should have a dana 44. Crawl under and verify it. I have seen a few that, for whatever reason, had a 36 instead. One of the stick cars I saw with a dana 36 was wrecked and clipped with an auto back half. The other was swapped with an auto and traded back in at lease end. Before you lay down your cash, confirm you have a dana 44.
Old Jan 19, 2006 | 10:19 PM
89vettefromhell
i just checked my chiltons and confirmed its the D44 but now i need to know what/if splines and teeth count matter... im looking at a set of 3.73s outta a D44 jeep 4wd and wonder if they will work!
Old Jan 19, 2006 | 10:24 PM
Pete K's Avatar
Pete K
My point is, Chilton cannot confirm that someone(prior to you owning your car) did not swap out your dana 44 for an automatic cars dana 36. I have seen this done.
Old Jan 19, 2006 | 10:33 PM
89vettefromhell
how can u definitly check.. my chiltons said check for some numbers and i did and those numbers were for the D44
Old Jan 19, 2006 | 10:41 PM
Pete K's Avatar
Pete K
I would imagine the numbers tell the tale. My car had no numbers. The dana 44 has 2 bolts in the top of the batwing. One at each corner. The 36 has 1 bolt at the top. It is in the center though. That is the quick way that I take a fast glance and determine which is which.
Old Jan 19, 2006 | 10:50 PM
89vettefromhell
TY much thats all i need ... a check to the garages turns out that it yes is definitly a 44... now do you know if a set of 3.73s from a 4wd jeep cherokee would work?
Old Jan 19, 2006 | 10:57 PM
Pete K's Avatar
Pete K
I am 90% sure that they will not work. Every time I see the gears listed, they are the same part number as the Viper gears. The trucks usually carry a different part number.
Old Jan 20, 2006 | 01:02 AM
89vettefromhell
anyone got any links to some Corvette D44 Gears???/ i wanna see the specs on them like how many splines and what not i cannot find what number splines/teeth should be on the corvette ring and pinion
Old Jan 20, 2006 | 02:12 AM
vader86's Avatar
vader86
my website has links to some places that give full specs on their gears
To how do i tell what diff i have?
