SuperRAM with MSD HEI DIST???????
I have heard it is slightly larger than the normal HEI cap.
I do know with a normal HEI cap the amount that you can rotate the cap is limited due to the back corner of the SR plenum.
A solution some members use is to go to a msd 8366 with a pictail connector so it plugs in and all you need is a coil.
This is the small cap style so adjusting timing is easy.
Sorry I don't know more about this specific cap myself!
