I am about to do a complete tune up on my 85. I plan on buying plugs, wires, cap, rotor, pcv valve, filters, etc. My question is, would buying these parts from a parts store be sufficient? I work at a pep boys and receive a 20% discount, so it would be significantly cheaper than going to the dealer. However, I don't want to sacrifice quality or performance to save a few bucks. The brand that pb carries for wires/cap/rotor is borg warner. I haven't really heard much about them in terms of quality or performance. Are these good enough quality to use in my vette, or should I pay more and just go to the dealer? Thanks much.
So do you think the borg warner cap/rotor will be fine, or should I go to the dealer and go with delco?
The B/W is probably fine, and probably all made in the same place.
I agree w/delco but I looked at price, around here the stock cap was almost same cost as aftermarket (approx.$27.w/rotor). Pertronix, msd, accel etc. (brass terminal, high tech. plastic?) are all the same price, and IMO all made in china, so it becomes color (coil, dust cover etc. are direct fit).
The other issue with the aftermarkets is almost all have the clamp down screw, so if yours has the straight screw down this would need to be modified.
The wires however are different MSD's, taylors 8.5 cost around $80. The stock type of system is actually (less wires), good and can support a mild built sbc.
The BWD parts are plenty good. Borg Warner markets a set of plug wires that have a spiral wound metallic core. I forget their name for them. They are excellent wires. You can spend a whole lot more than the than what the BWD parts cost, and end up receiving nothing more.
RACE ON!!!
Yeah, I was thinking about those wires, they're called borg warner select. I could probably get those for about $35, about $20 less than what the msd wires cost. Which ones would you reccomend going with?
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
i did the same thing a while ago and decided that for the price, i would try the hypertech-dui, cap, coil and rotor combo. the car starts very quickly now, and as far as i'm concerned it was definitely worth the ecomomical extra bucks. i believe it was around $75 from summit. as i remember--a cap and rotor were running around $40 bucks by themselves.
frog.
frog.
Just low much faster does it start now as opposed to the less expensive parts you didn't buy?
I am really not sure why there is a need, if you are spinning the motor up and over 5500+(modded out ) I could see maybe a coil swap. The stock peices are pretty well balanced. The brass terminals allow some easier clean-up over allum. but the plugs, wires etc, can only use what they can handle.
If you get a 20% discount go with the Pep-boys. Just get their higher quality parts. Get the best plug wires you can, I think they were the hardest tune-up item to replace. Use a plug socket and an open end wrench to remove and tighten #8 plug. Good luck and enjoy!
