Heated O2 sensors?
Old Jan 22, 2006 | 05:38 AM
corvette1989bham's Avatar
corvette1989bham
Default Heated O2 sensors?
Do C4's (and what years) have heated O2 sensors ...besides the obvious, what is difference in heated vs. regular?
Old Jan 22, 2006 | 09:09 AM
Nathan Plemons's Avatar
Nathan Plemons
I'm afraid I can't accurately answer the first part of your question as I don't know exactly when the switchover was made.
For GM you'll see essentially 3 types of O2 sensor, single wire, three wire, and four wire.
Single wires are non heated standard O2 sensors. Three wires work exactly the same and can directly be swapped for single wire sensors with a little wire splicing and will function just fine if you don't hook up the other two wires. The two extra wires are the heater, polarity doesn't matter, just connect one end to a fused / switched 12v source and the other to ground.
Four wire sensors have an additional wire that I believe goes back to the ECM for which I'm not completely sure about the purpose. If you're converting from non heated to heated it is easiest and cheapest to get 3 wire sensors.
Old Jan 22, 2006 | 11:53 AM
vader86's Avatar
vader86
Your 89 does not have a heated sensor. You do not need one if you run a stock exhaust in front, only those with headers may ever need it.
The difference is the extra wire to a switched 12V source that powers the heated element in the sensor, allowing it to read properly at 350C instead of the usual 600C.
C4Crazy787's Avatar
C4Crazy787
I know the '92 ZR1 has heated o2's (3wire) from the factory because that's the sensors I used when I upgraded to heated.
Here's a picture of my heated o2's and harness with factory weather pack connectors. Purple wire to ECM, one brown wire to "ignition on" 12v and other to ground.
http://www.digitalcorvettes.com/corv...nd_harness.JPG
Old Jan 22, 2006 | 12:33 PM
corvette1989bham
So your ZR1 came from the factory with heated O2's, but your say you UPGRADED to heated O2's..I 'm not sure I understand. Thanks for the picture, as they say a picture is worth a thousand words. If you know, or others know which C4's cars ZR1,L98,LT1,LT4 model years came with what, I would appreciate the knowledge ,mainly for my personal C4 repair notebook.
Thanks!
Old Jan 22, 2006 | 01:06 PM
vader86's Avatar
vader86
No L98 came with a heated sensor.
Old Jan 22, 2006 | 01:37 PM
C4Crazy787's Avatar
C4Crazy787
Thanks!
No, I have a '92 LT1, it did not have heated o2's from the factory.
Old Jan 22, 2006 | 02:34 PM
aboatguy's Avatar
aboatguy
My 95 came with heated sensors!
After further research I believe that the '94-'96 LT1s have heated sensors!
Old Jan 22, 2006 | 03:31 PM
corvette1989bham
Thanks...anyone else?
Old Jan 23, 2006 | 10:11 AM
Lichen's Avatar
Lichen
My '93 did not come with heated sensors (but I'm switching over because of headers). The switch to heated must have come in '94 or '95.
Old Jan 23, 2006 | 11:45 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
The confusion is cause some 94 have em and some don't. ALL 93 and down do not have a heated O2 sensor.
I have no clue about ZR-1s.
Old Jan 23, 2006 | 12:25 PM
JAKE's Avatar
JAKE
I recently came across a long over-looked point in the Corvette Shop Manual about Open Loop/Closed Loop operation.
Manual says that the system may drop out of Closed Loop at Idle when the 02 cools off too much.
Seems that GM knew about that tendency way back at square one; something we with headers tended to think was unique to that mod.
If I come across the page number again, I'll post it.
Jake
To Heated O2 sensors?
