Best way to "create" a key'd power source?
So I'm thinking of running a heavy guage wire off the battery terminal with a fuse TBD, and then use a relay that would be wired in to a keyed ignition source.
Any thoughts on how to best accomplish this? What components to use (terminal posts, etc) that would work for the weathered underhood environment?
Some links:
http://www.digikey.com
http://www.newark.com
http://www.mouser.com
Also, keep in mind some of the manufacturers might offer free samples, so it might be worth checking out their site as well to investigate that. For example, I build my own RS232->ALDL interface all with samples, even including the OBDII connector which at the time was fetching upwards of $60 each (excluding discrete components I had at work of course).
Have you looked at the offerings from Painless?
connector. This could be mounted on the fender liner and look just like
it belonged there.
The switched source could be a circuit from an existing relay (fan, fuel
pump?). You might have seen a recent thread where I posted about
opening up a relay instead of splicing into the OEM harness - either
way would get you a switched & fused source for the new relay.
As for the main HD circuit. Instead of wedging a ring terminal under
the Pos battery cable, consider connecting to the terminal block that
sits behind and below the battery tray. At least there is one on my
'89. This single terminal is the distribution point for several of the
'always hot' OEM circuits - note that fusible links are present for
protection.
As for wire - I caution against using GPT insulated wire. IMO, this is
inadequate for the engine compartment. You should look for TXL, GXL
of SXL grade wire - SXL is probably going to be easiest. Marine grade
wire has a higher temp rating than GPT, too. (Not sure but I think it
may be SXL from some vendors.)
Painless sells TXL in virtually every colour and stripe combo used for
GM (and other) OEM harnesses. The issue is that retail performance
outlets don't/didn't regularly stock Painless Extreme bulk wire. This
is much better than GPT!
But unfortunately they don't carry weatherpack connectors and all that which is what I'd like to use. THose I've already ordered. However, I was primarily looking for an easy way to setup a relay and a hot tower that would be "weatherproof" so I wanted to avoid just running a 12 guage wire off the battery and then just splicing into it. But I could probably keep it that simply with a good relay and insuation....That's why I posted though - I'm getting ideas that I'd never think of on my own!
the relay and choose how it functions, Hella is the way to go. I used
a number of their products on the NEP and am very happy with the
way that came together.
If you want to check out Hella, take a look at the SUSQUEHANNA
MOTORSPORTS site. It may take a while to get your head around
the permutations and combinations Hella offers, but SUSQUEHANNA
is a good place to start.
For fusible link wire, NAPA carries Belden products you can use. They
also have the nice Belden in-line mini-fuse holders.
There is a slick Maxi-Fuse holder I sourced, too. It has an optional
clear dust cover that was hard to get but this added the finishing touch.
I located this somewhere other than NAPA - if it is of interest, let me
know and I'll look back for the details.
As for WeatherPack, MetriPack and other under-hood connectors,
I found that I was able to get everything I needed locally from
commercial/industrial electronics houses. The Deutsch Connectors
(weatherproof and much more compact) as sold by MSD, proved to be
a little harder to come by in bulk when I was looking - you can get them
from MSD vendors if you only need a few.
Ramanstud,
The 1984 doesn't have the junction block or buss bar behind the battery like the 1985 and up cars. Rather than cause a compromise with too many wires connected to the battery positive post, run a heavy gauge wire (#8?) from the large stud in the starter, where the battery positive cable connects and run it to... wherever. Behind the battery seems to work for later years.
RACE ON!!!
