ASR/ABS acting weird
Old Jan 23, 2006 | 02:58 PM
Lichen's Avatar
Lichen
Default ASR/ABS acting weird
For the last few days, my ASR and ABS lights have been coming on about half the time. The brakes feel fine, but the ASR is really weird. One morning it kept kicking on and off every two seconds. I switched it off, but it isn't working at all even when it is on now. I discovered this yesterday when I hit second gear on the freeway on-ramp. Almost turned me sideways from the fishtailing. Any suggestions?
Old Jan 23, 2006 | 04:16 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your brake fluid level. Both the ABS/ASR systems rely on proper fluid levels to function properly.
Are you seeing a weird display on your car's DIC i.e. multiple guage alerts, flashing lights, etc? That's one sure-fire indication of low brake fluid levels.
Old Jan 23, 2006 | 04:29 PM
Lichen's Avatar
Lichen
No flashing lights. They either go out when I start the car, or stay on during the whole drive. I'll check the fluid, I think it's alright, but I do need to do a complete flush of the system.
Old Jan 23, 2006 | 05:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I was getting an ASR/ABS code as well as a low voltage code for the TPS. I traced it down to and replaced the connectors in the TPS plug and it took care of the problem. Get a male pin and check the female connectors in the TPS plug. If they don't fit very snuggly they can cause problems. The module for the ASR/ABS gets a signal from the TPS.
Old Jan 23, 2006 | 07:54 PM
Lichen's Avatar
Lichen
Thanks for the advice. This afternoon they worked perfect. I added about 1 oz of fluid. Maybe an electrical gremlin, but I will take your advice.
Old Jan 23, 2006 | 10:49 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I know you have been getting some differing opinions, and you should probably check them all out. I was having a similiar idiot lights going off intermittently over the period of a few days. I added brake fluid to the master cylinder resevior and the lights went away. I then decided it was time for a brake overhaul anyway and put the J55 GS option on with new SS lines and fluid. No lights have ever came back since then.
Good Luck
Old Jan 24, 2006 | 12:41 AM
bogus's Avatar
bogus
you don't mention your tires. I have found that once the tires start to get thin, they really set off the ASR.
Otherwise, the fluid, TPS and such are great starts.
Read this:C4 Guru - Reading CCM Codes
Old Jan 24, 2006 | 10:12 AM
Lichen's Avatar
Lichen
The tires are still good. This morning the lights were back on and the ASR was non-functional.
Old Jan 24, 2006 | 11:30 AM
bogus's Avatar
bogus
check the codes... The EBCM stores codes unique to the ABS/ASR system. I would not be surprised if a wheel sensor has failed or something.
To ASR/ABS acting weird
