What do you guys think?
Old Aug 6, 2001 | 10:20 PM
Kehrer923's Avatar
Kehrer923
Default What do you guys think?
I have a 383 LT-1 it has the following componets, and I was wondering hat some of you experinced guys think it should perform.
383 c i
6 in oliver rods
srp flat top pistons
11:1 compression
afr 195 competion ported heads
2.020 intake 1.6 eht
cam 239 239 @.50 595 595 lift 112 lobe center
ported and gasket matched lt-1 intake
54 mm asm billet throttle body
26lbs injectors
msd 6al
3:73 gears and zf-6spd
the desktop dyno said i should break 500 ft lbs and 500 hp
what do you guys think :rolleyes:
