L98 Timing marks...
Old Jan 24, 2006 | 02:18 PM
HeeHaw89's Avatar
HeeHaw89
Default L98 Timing marks...
can someone post a pic or just draw me the timing marks on a L98. I'm having a difficult time seeing the numbers on mine, but I can still make the lines out.
TIA
Old Jan 24, 2006 | 06:06 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
The edge of the timing marker looks like a series of V's. The bottom of the largest V is 0 or tdc. Each top and bottom from there is 2 degrees whether you go up the marker, (advanced) or down, (retarded).
Definitely not the best explanation but couldn't think of another way to put it.
Old Jan 24, 2006 | 07:39 PM
Eike's Avatar
Eike
hope that helps ...
e.
Old Jan 24, 2006 | 10:03 PM
87 rag's Avatar
87 rag
What everyone else said is correct but the center of the deep 'V' or 0* is 4* from the first peaks in each direction. Then the smaller valleys are 2* in and 2* out.
Hope this makes sence.
Old Jan 24, 2006 | 10:27 PM
HeeHaw89's Avatar
HeeHaw89
Thanks, I knew they were spaced 2 deg just wasn't sure which number marked which line...Eike, I can't imagine that you took that perfect picture for any other reason but to help me...THANKS
Old Jan 25, 2006 | 02:23 AM
Morley's Avatar
Morley
Scrub the tab with some steel woool. The rust or whatever else that is making it hard to read will be left in the impressions for the numbers and lines and will stick out like a sore thumb then.
To L98 Timing marks...
