emissions failure-need help with interpretation and solution
Car:
'89 with 165 ecm L98 MAF and zz4 cam installed since last test
e-test type:
asm2525 test on rollers at 25mph
Results:
Just as suspected, I failed emissions because my HC ppm was 86 with a limit of 58.
Now, NOx was way down from previous test taken with stock cam at only 37 ppm with an allowed 652 ppm.
CO% allowed was .32 and I registered .19.
Idle is not an issue, although HC levels are close to limit
I believe I know what to do to get this situation looked after. I'm thinking of raising the timing in the test area (on the rollers, btw) to decrease HC. I know full well that this might adversely affect the other reading but it looks like I have a lot of "wiggle room" in the Nox department. Not that much in CO.
What do we think and most importantly, by how much do I advance to see a difference?
Please check everything and retype it carefully.
Opinions?
Bumping the timing up to reduce HC... hmmm, I'm trying to figure out the science behind that. NOx is relatively easy because high cylinder pressure/heat cause it to form, and retarding the ignition timing drops that pressure pretty quick.
I'd search more for:
1) misfiring cylinder
2) too rich mix
3) bad cat
You've got an '89 like mine, so if you're running the original injectors, you may have some problems there. In my case, I had 2 bad injectors on the driver's side of the motor, which is the only side the O2 sensor monitors. What happened to me was the driver's side was running too rich because of the bad injectors, and the ECM was leaning the fuel mix to compensate. The problem was, the passenger side of the motor ended up running too lean, to the point I was getting lean surge. I could see your driver's side cylinders running a bit lean (clogged injector, whatever) which is making the passenger side run too rich. Can you read all the plugs to see if any cylinders look like they're running rich?
Also, is your air pump intact and the line running from the air pump to the cat intact? I believe one of the purposes of that line is to supply excess air to the cat for the oxidation stage of the cat--where HC gets converted to H2O and CO2.
Good luck!
Ben
