Why not aluminum headers?
Old Jan 26, 2006 | 12:58 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Alvin
Convection isn't going to save your butt. check out the Cp of air vs. water
The reason why your heads/block/whatever stays cool is because it has a coolant pulling heat from them. If you depended on air alone it woudl take 4 times as much air as water in MASS. Considering the density of water is around 1000 times that of air your talking about moving quite a volume of air to remove the same heat.
thermal conductivity isn't the worst problem.. The problem is the parts would loose their toughness (resistance to plastic deformation) starting at temps much lower than you'll see here.
So in short.. to use a aluminum alloy for a exhaust manifold or header you would have to use some sort of coolant, build them to where the COT isn't going to break anything when the parts get hot, and build them thick enough to where the parts aren't going to deform when the modulus of elasticity goes threw the floor.
Everything you said here is true. You misunderstood me. Heat loss through a stainless header vs aluminum one isn't a big difference because 99% of the thermal resistance is in the boundary layer. Obviously the ID layer will be less than the OD layer, but my point is the pipe ID and OD will be close in temp, but somewhere in between the exhaust temp and outside temp. It'll be closer to the gas temp than the outside temp because of the exhaust velocity, but definitely cooler than the gas temp. Obviously not cool enough though as Pontiac discovered.
The math is already done, I have an old work project using THERM and excel to run 1D and 2D temperature profiles through window frames to check for condensation and heat loss, so I just plugged in some different materials.
Old Jan 26, 2006 | 02:27 AM
Morley's Avatar
Morley
.. They claim "scientifically" that jet fuel isn't hot enough to melt steel.
As a Jet Engine Mechanic in the A/F for 12 years I can safely say To their "theory". The tempratures in a jet engine (burning jet fuel) can and will melt titanium.
Another reason to vote against alum. headers is metal fatigue. The constant heating and cooling along with the vibration of the engine will soon crack any alum. alloy that can withstand melting from the exhaust.
Old Jan 26, 2006 | 08:33 AM
loiq's Avatar
loiq
Two stroke jet skis use aluminum pipes in race applications. I've been to place that makes them - they're expensive, $1200 for a set for a three cylinder engine.
Old Jan 26, 2006 | 08:44 AM
aboatguy's Avatar
aboatguy
Do jetskis have a dry exhuast?
Old Jan 26, 2006 | 08:54 AM
Slalom4me's Avatar
Slalom4me
I don't know, but I DO know that the aluminum exhaust manifolds I used
to see on Olds 455's in recreational jet boats were wet - cooled by the
coolant circulating in the engine.
Old Jan 26, 2006 | 01:47 PM
loiq's Avatar
loiq
Old Jan 26, 2006 | 01:59 PM
350ws6's Avatar
350ws6
Alvin, using a material with 3-10 times the thermal conductivity will certainly NOT yeild 3-10 timed the underhood heat.
The external convection resistance is the main resistance in the overall heat transfer from the exhaust to ambient.
You may reduce the conduction resistance by 50%, however if is the conduction resistance is only 1% of the overall thermal resistance from the exhaust to the ambient air the actual change in heat flux is not going to be very noticable.
Headers are very thin, the conduction resistance is pretty small compared to a cast iron manifold
For a quick check assume 200w/m*k for aluminum and a heat transfer coefficient of 5-10 ( roughly natural convection) on the external surface of the pipe.
Old Jan 26, 2006 | 02:26 PM
Aurora40's Avatar
Aurora40
Originally Posted by CentralCoaster
I don't see why exhaust heat would be a problem, it couldn't be too much hotter than aluminum heads run in the chamber. Even then, they could be ceramic coated inside and out. It's not as if the aluminum is gonna melt.
I'm no expert, but I would imagine they could melt. Heads don't get nearly as hot. Headers can run so hot they glow. Pistons and heads don't do that. Not that much of the heat of combustion is absorbed by the heads and pistons. It is mostly pushed right out the exhaust. I'd think the headers would soak up a lot of it, and not have a good mechanism to shed it.
Old Jan 26, 2006 | 02:44 PM
CentralCoaster
Well said. And don't forget about the resistance of forced convection on the ID. It's less, but still a significant factor.
Old Jan 26, 2006 | 03:27 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The exhaust from two-stroke engines is MUCH cooler than the exhaust from a four-stroke. It has to do with the exhaust gases being contaminated by the cool intake charge.
In addition, race applications place performance/weight reduction over durability....I'm betting those pipes require frequent replacement.
Larry
code5coupe
