"Frisbee" removal tips?
Old Aug 7, 2001 | 01:20 AM
BobMachus's Avatar
BobMachus
Default "Frisbee" removal tips?
I am going to remove the water pump "frisbee" tomorrow. Do I just remove the bolts and remove the disc? Do the bolts need to go back in? Any good reason NOT to do this? I assume (and we all know the danger that goes along with assumptions) that this is just a balancer/damper of some sort? Thanks, Bob
Old Aug 7, 2001 | 01:24 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: "Frisbee" removal tips? (BobMachus)
Sounds like you're after that 10 free HP.
Mine had studs. I removed them and used bolts to hold the water pump pulley.
Old Aug 7, 2001 | 01:48 AM
BobMachus's Avatar
BobMachus
Roger that on the HP 65Z01, thanks for the tip.
Old Aug 7, 2001 | 03:02 AM
moffitt's Avatar
moffitt
I find it extremely hard to belive that it takes 10 hp just to spin that disc!
If that were true, just imagine how much it takes to spin a flywheel!
Must be atleast 500!
Just a thought.
Old Aug 7, 2001 | 06:23 AM
Shayne's Avatar
Shayne
whats the frisbee thingy you guys are talking about??How do I know if I have one? Got a pic?
Old Aug 7, 2001 | 10:16 AM
Vic'89's Avatar
Vic'89
Default Re: "Frisbee" removal tips? (Shayne)
I am not sure if all L98's had the frisbee, but my 89 had it. My water pump has studs that hold the pulley and frisbee on. I just unbolted the frisbee and put the bolts back on the pulley.
Vic
Old Aug 7, 2001 | 02:22 PM
89_FX3_6-spd's Avatar
89_FX3_6-spd
Default Re: "Frisbee" removal tips? (Vic'89)
From what I understand the "frisbee" is there to reduce the torsional stresses :smash: on the alternator and drive brackets. I think at least one person wrote in that he removed the frisbee and then notice the bracket cracked near the alternator :eek:
Old Aug 7, 2001 | 03:08 PM
BobMachus's Avatar
BobMachus
Default Re: "Frisbee" removal tips? (89_FX3_6-spd)
EEK! Well, We will see what happens. I got the frisbee of with no real problems, and while it is heavy I also find it hard to believe it takes 10 hp to spin that disk. it might be worth 2 or 3 tho, and they all add up. Plus it is much easier to see timing marks, etc, now. Thanks for the help guys. I'll get back to ya if I have probs as a result of this. Later, Bob
Old Aug 7, 2001 | 10:17 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: "Frisbee" removal tips? (65Z01)
:bs
To "Frisbee" removal tips?
