removing tilt lever
Old Jan 26, 2006 | 12:06 PM
dbriana's Avatar
dbriana
Default removing tilt lever
What do you use to unscrew the tilt lever, I see a notch there, and tried by hand but no luck. TIA
Old Jan 26, 2006 | 12:11 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
You can use a very tiny adjustable wrench.
You can also use a tiny pair of vise grips. I usually put some electrical tape around the notch so as to not scratch the lever. A small piece of cloth also works.
The lever turns out towards the dash / front of Vette. Screws back in towards the rear.
Good Luck!
Save The Wave!
Old Jan 26, 2006 | 08:33 PM
pwrful c4's Avatar
pwrful c4
Good Luck!
Save The Wave!
same here
To removing tilt lever
