How does a 90 degree V-6 work?
Old Jan 26, 2006 | 02:59 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default How does a 90 degree V-6 work?
How'd Chevy get away with a motor that doesn't have a balanced firing order? I would think the V6 would have to be 120 degrees.
There's gotta be two deadspots in the firing order. Seems that would be difficult to balance or rev high.
3 power strokes per revolution, but two of those strokes will have to be 180 degrees apart.
So does a 3.8L run as well (or as badly) as a 5.7L with two dead cylinders?
Old Jan 26, 2006 | 03:20 PM
Yellow95's Avatar
Yellow95
90 degrees refers to the banks of cylinders being 90 degress apart. There is a plug fire every 120 degree rotation of the crankshaft.
Old Jan 26, 2006 | 03:25 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Well,they always said to picture the 4.3 V6 a chevy V8 with 2 cylinders chopped off.
Old Jan 26, 2006 | 04:20 PM
CentralCoaster
Ahh the miracle of google.
The crank throws have a "splay angle" on them. Same for flat-6's. There is essentially a seperate throw for each cylinder, not paired up like our beloved v8.
Without splayed throws, like on a 90* V8, the block angle has to match up with the angle of firing. A V8 could be made flat or 90* with non-splayed throws... but I guess it's not balanceable.
A V6 would have to be 120* if not for splayed throws.
Here's some good reading:
http://www.autozine.org/technical_sc...ne/smooth1.htm
Here's a splayed throw.
CentralCoaster
What does the crank on a 3.8L look like?
Very different from the 350 crank. And I wonder if the connecting rods or pistons are offset a little too because the rods cant be put as close together.
Old Jan 26, 2006 | 05:45 PM
kopbet89c4's Avatar
kopbet89c4
Isn't a 3.8L V6 comparable to a 305 ci 5L V8 just with 2 cylinders chopped off??
Old Jan 26, 2006 | 05:46 PM
TIMSPEED's Avatar
TIMSPEED
Hmm..when you look at a 4.3L, it looks JUST like a SBC with the rear two cylinders cut off...but I bet the crank looks WAY different.
BTW: I dunno about them 3.8L's but they sure are fast!
Old Jan 26, 2006 | 06:10 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Aren't the Chevy V6s even fire? That is that all cylinders fire an even number of degrees apart? I'm thinking that the Buick V6 is the odd fire engine. I used to work on a lot of these but it's been a goodly number of years ago. Back in the 50s and 60s GMC trucks had an odd fire V6 of large displacement. I remember a 401 among other sizes. They were some serious torque-making bastards.
Old Jan 26, 2006 | 06:27 PM
bogus's Avatar
bogus
This is one of those things that has always made my head hurt... those stupid GM V6's...
The 3800 will run with the best of 'm, tho...
Old Jan 26, 2006 | 06:43 PM
jfb's Avatar
jfb
Ever sit in a V6 car idling and not have it shake? I haven't.
Old Jan 26, 2006 | 06:49 PM
robs87vette's Avatar
robs87vette
my wife's 3.8 04 Grand Prix GT
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Shake? Really? To answer, yes, I have sat in V6 cars and there's no shake. Maybe it's unique to 3.8GMs, but I've sat in those, too. Don't recall shaking at idle. I've also sat in Acuras, Infinitis and Lexus V6s, no shake that I recall. Could be mount dampening tho.
Old Jan 26, 2006 | 07:06 PM
CentralCoaster
They do have even fire. It's the crankshaft that I didn't think about. Read that link and it'll all make sense.
Old Jan 26, 2006 | 07:10 PM
CFI-EFI's Avatar
CFI-EFI
I don't know if they are still made this way or not, but the original 231 CID Buick (3.8L) used a V8 distributor cap with only 6 wires installed. THAT is evidence of an odd fire engine.
The 4.3L Chevy, 90°, V6 is essentially a 350 V8 with cylinders 4 and 5 removed. Unlike the Buick, the Chevy's offset, Siamesed, crank throws allow for an even firing order, in a 90° block.
RACE ON!!!
Old Jan 26, 2006 | 07:15 PM
CentralCoaster
Ahh, that is a good indicator! Nothing seems to go over CFIs head. I guess if the whole world was made up of gearheads and engineers, there'd be no one left to pick up the trash or clean the toilets.
Old Jan 26, 2006 | 09:23 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
What's this shaking at idle? My truck and my Vette are the only cars I've owned that did not have the 3800 V6 (I love that motor!)... and I have never experienced this shake at idle. Not in the Gen I or Gen II motors. Might be a good idea to check your motor mounts...
Old Jan 27, 2006 | 05:32 PM
bluealtered's Avatar
bluealtered
The 4.3 in my 93 forest service crummy has a balance shaft up by the cam and lifters, since i haven't looked to make sure it's for the crank i will guess thats what it's for,.....untill spring when it (the 4.3)comes out to get freshened up. ...
To How does a 90 degree V-6 work?
Old Jan 27, 2006 | 05:53 PM
lt4red's Avatar
lt4red
The throttle body injection did not have the balance shaft, I think they started that with the CPI injection to be able to idle down to 600 rpm.
Old Jan 27, 2006 | 07:07 PM
bogus's Avatar
bogus
Didn't the Gen II 3800 add the balance shaft?
The old Chevy 2800, 3100, 3400 and now 3900 is a POS... I guess it has gotten better, but gee, the older versions were as nasty as they come.
I do like the 3800 Buick, tho. That is one sweet little motor.
Old Jan 28, 2006 | 11:18 AM
shadetreeperf's Avatar
shadetreeperf
I think that the chevy 2.8, 3.1, and the 3.4 were actually buick motors and they were 60* blocks not 90* like the 4.3.
