Wolverine Cam??? Are they any good on the L98
We bought the white coupe and just got her running well. The cam seems to run well and idle is pretty good. Sounds REALLY nice with the Borla mufflers. It has a stock chip and looking at the cam sheet, I think that's bad, what do you think:
cam lift:int.305,exh.305
valve lift:int.458,exh.458
lobe ctrs:int.105,exh.115
adv dur:284int.,284exh.
.050 dur:218int.,218exh.
adv timing:
BTC-36 ABC-68 BBC-76 ATC-28
.050 timing:
BTC-4 ABC-34 BBC-44 ATC- -6
Thanks.
adv timing:
.050 timing:
Thanks.
Re: Wolverine Cam??? Are they any good on the L98 (jcygan)
I'm surprised it runs. Mine wouldn't with the stock chip and a 218/226 114 LSA cam. Your stock timing and fuel will be off. Time to learn to burn chips.
