okay so i bought some straight pipes for the vette. no cats, no mufflers. it seemed to running right the first few days then i noticed when i'm at a stop light the idle fluctuates but will eventually return to normal (this happens everytime you come to a stop. i've got the little black emissions box capped off where the hose went that lead to the center cat. can anybody explain this.
by the way the car has a mild cam with egr block off and is an automatic
Interesting... I'll have to reset everything sometime with that detail in mind. I've had a small issue w/ idle fluctuation for years but there is one symptom that has baffled me.
It only does it while the car is moving & either clutch in or coasting in neutral. As soon as I come to a stop the idle drops to where it should be & stays there.
