Time to get a new cat/cats?
Old Jan 27, 2006 | 07:40 PM
4REGT4's Avatar
4REGT4
Default Time to get a new cat/cats?
((95 LT1 6spd)) - -I know I asked this a while back when I was concerned about a cats lifespan relative to miles (yeah yeah yeah - no need for 9 lives jokes here). Anyway - my car has about 84k miles on it and was originally told they should be fine for quite a while longer (Mr. Mojo mentioned his were at about 132k or so and just fine -dont remember the exact mileage he stated).
- - - My question now is addressing whether at least one of mine could have been screwed up when my O2 sensors were destroyed to an oil leak (both problems have been fixed). I was told that during this problem I had a LOT of black smoke coming out the right exhaust side of the exhaust. Ever since it was fixed the idle hasn't been as smooth as it used to be (just a little bit of wavering in idle and sound - nothing too major). Also it doesnt seem to be quite as poweful as it was beforehand. - - - Is it possible that the cat was gunked up and that one or both of the cats should be replaced? Could they cause these symptoms? Should I replace them anyways? If so - what is the cheapest (or best value) direct replacement that will equal or improve the airflow over stock? Thanks for any help with my questions..............................
Old Jan 27, 2006 | 07:58 PM
CFI-EFI's Avatar
CFI-EFI
Of course! Just drive it into the nearest Chevy stealership and have then install a couple of grand worth of new cats. Or maybe it wouldn't be a bad idea to TEST them!!!
RACE ON!!!
Old Jan 27, 2006 | 08:06 PM
4REGT4's Avatar
4REGT4
Sorry for my ignorance, but how would I go about testing them?? I have never had any experience with any cat equipped vehicles. As I've mentioned before - I WAS looking for a good 69 before I was forced into making a decision based on what was available. I'd replace them with staraight pipes if I wasnt worried about cops (I am putting on Flowmaster Super 40s very soon). I suppose if the Flows arent too loud or ahve too much int res. I may consider straight pipes in place of them.... as for 2k on cats...I would be cutting and welding everything myself.. just dont know anything about what to get.
Old Jan 27, 2006 | 08:20 PM
CFI-EFI's Avatar
CFI-EFI
Check the back pressure.
RACE ON!!!
Old Jan 27, 2006 | 09:54 PM
Strick's Avatar
Strick
I'm not sure about FL and their inspection requirements. It seems that Random Tech makes a good high flow cat for our Vettes. When you start the replacement, that would be a good time to drop in a set of long tube headers. I don't think you'll like the Flowmaster 40 series as the resonance is horrible. This is what I think you should go with for starters: Long tube headers, random high flow cats, connected to your OEM exhaust. If you want some fun noise, go with some muffler eliminators. If you want to spend lots of cash, slap on a set of Corsa or B&B catback systems. Both look and sound pretty good.
Old Jan 27, 2006 | 10:09 PM
MikeC4's Avatar
MikeC4
RACE ON!!!
CFI, how do you test for back pressure?
when i replaced my cats last year, i could barely see daylight looking through my old passenger side cat, which i suspected was bad. i think that black soot from rich running engine collects and builds up in the honeycomb. New high flow cats and O2 sensors(i was getting O2 error code for right side) made a vast improvement in idle and overall driveability. i had about 68K miles when i replaced.
Old Jan 27, 2006 | 10:26 PM
Jerris's Avatar
Jerris
You have conditions that would lead to a partially pluged cat, bad O2 sensor, oil in the exhaust and lack of power.
The only way to test for a restricted cat is to disconnect it and see if the power comes back.
Since you can weld, you could temporarily put in a piece of pipe so that you can road test it. If the power comes back and the idle smoothes out you know that it is time to replace it.
If the power does not come back it is not the cats, however you could still have a restriction in the exhaust at the mufflers.
See my post in "what does it take to plug a cat", kind of long but it may help. I might expand on it and start a new thresd with some facts on cats.
Hope this helps
Jerris
Old Jan 27, 2006 | 11:05 PM
4REGT4's Avatar
4REGT4
FL has no emissions tests whatsoever. And I have already purchased the Flows - and I do like their sound (I don't mind how loud it is inside the car - that is what I grew up with as my father deals in vintage Ferrari race cars) . I had flows on the Ferrari in my avatar for some time, but that killed my torque on that motor since I used a Camaro set-up - - 2.5 transverse over 2.25 stock (eventaully spent the 2k for a new factory one) . - - - Aside from that - I also thought about cutting the cats (as suggested) and welding straight pipe in there to see if I got my power back. That may very well be what I do when I put the new mufflers in (planning on doing that this Sunday). Still would like to know what to get in the event that I do in fact need to replace my cats. And it sounds like that may very well be the case. - -Thanks again for everyones help in this matter. It is much appreciated. I've got got two dual 3" Hooker tips coming for the system too that should look pretty good - I will update my pics and probably get a video sound clip up here when that is done. May wait for the vid though if I find that the cats do need to be replaced.
To Time to get a new cat/cats?
