Looking at the front of the engine I think it turns counter clockwise. After a new rack install, I'm trying to bleed air without running the engine. I would like to rotate my PS pump with the belt off and want to make sure I turn it the right way.
After getting the belt back on, I see that your right...the PS pump runs CCW. I used a small belt to turn the pump with a drill. I'm sure it was turning slower than it would with the engine at idle, but I did not want to start the engine. I hope it didn't hurt it to run backwards. I might try again tomorrow running it the other way, or I might just wait until I get done with a brake project and pull the car out of the garage and bleed it right.
