Paging Mr. Mojo
Old Aug 7, 2001 | 02:27 PM
GlockLT4's Avatar
GlockLT4
Default Paging Mr. Mojo
I had someone e-mail me that isn't a member of the forum and saw a video of yours from the track. They want to know what cam you are running in your vette..
[Modified by Glock'94, 12:27 PM 8/7/2001]
Old Aug 8, 2001 | 08:54 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: Paging Mr. Mojo (Glock'94)
he is completely stock inside the engine, if i remember just an open air lid and eliminators
Old Aug 8, 2001 | 09:04 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Paging Mr. Mojo (My 95)
see sig :cheers:
Old Aug 8, 2001 | 12:06 PM
95CYC4's Avatar
95CYC4
Default My First Post
Vette Owners,
I have been reading the forum for a few weeks now and finally joined up. I have learned alot from you all and wish to thank you all for the tips and tricks. I just did the opti/wires/coil/plugs/water pump change and have learned alot about my car. It's a 95 LT-1 6 spd coupe. Is it true they only made 1003 CY's in 95? And even fewer in 96? The previous owner abused the car, and I am going broke trying to fix everything that is wrong, but i'm very happy that I bought this car. I will have many more posts on here for tips to help my car out. The car is running like new since the ignition and coolant system fixes. I will race at E-Town soon, hopefully the weather can cool off for next week, or at least let the barometer rise just a little.
I do have one question for Mr. Mojo. I asked Glock to ask you about your cam. After watching your shift video I saw that you shift at the same rpm's that the LT-4's shift at(somewhere in the low-mid 6000's). Is the power band on your LT-1 different than the other's produced in 95? I am very curious. I haven't tried to rev my car up that high yet, but I wonder why you are doing it. Did you change your cam, or to make up for the rpm drop, you rev up your engine to get it into the power band at a better rpm. I don't know what the stock rev limiter is on our cars, so is your rev limiter set higher than stock? I just watched the movie again and want to know why you do it. I know that you got some fast e.t.'s, but saying that you have a stock valvetrain gets me wondering. I am sure that i'll see you again at E-Town. I will try shifting like this on the way home today. I will get some runs in soon to try and see if shifting higher makes any difference in our LT-1's. Also to go 108 mph you need to make more horsepower(somewhere around 320 or so) than our cars made stock(300 according to all the mags and GM data). After looking at your time slips I see that your mph and e.t.'s aren't that constant, and wonder how you can run 13.00's at 102 and 108 mph? That's a big difference in power between those 2 runs. I won't say anything else until I run my car. Ofcourse mine isn't all stock, but exhaust, MSD coil and wires isn't going to make a net 30 horsepower improvement. I guess i'll shut up till then. Drivers can make the difference, but you can't make horsepower appear out of thin air. Not trying to knock you, but it seems like we're missing out on something here.
Old Aug 8, 2001 | 12:49 PM
billyhay's Avatar
billyhay
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: My First Post (95CYC4)
Welcome to the forum. :cheers:
Mr Mojo and Patrick96LT4 are the masters of the six speeds. They are both more than happy to help anyone out.
Yes 1003 Competition Yellow cars in 95, 834 in 94, and my black book isn't new enough to give me a 96 number.
Old Aug 8, 2001 | 08:00 PM
Mr Mojo's Avatar
Mr Mojo
Steve, you bring up some very excellent points.
What the timeslips don't show are missed shifts and the weather.
On those timeslips where I had a 2.2 60' or higher, I either spun the tires or bogged down.
On those that show a 2.00 or less 60', I obviously hooked really well.
As far as the mph, some runs I let off early(bracket racing) so I wouldn't break out.
The 108 mph came in the late winter early spring in 35 degree weather.
Temp makes a big difference.
The video above, my engine temp was at 220, where normally I keep it at 150-160. That 60 degree difference in temp means a lot.
I ran 13.82@103 mph in that video. That's about 4 tenths and 1 mph off my normal for this time of year.
When you get down to E-town, look for me, I'll be glad to fill you in on everything about my car and the way I drive it.
I haven't done a thing to the motor or anything else. I still have the front sway bar in. The only "free" mod I've done is to cut open the air lid and that didn't do a thing to improve.
As far as my motor being different, I always kid around that mine was built before lunch, that's why it's better.
Based on my mph, most guys at the track agree that my engine is stock.
Mackey and Panuzzo(both LT1/automatics) were trapping at 106 mph before they did gears. So that goes to show the difference between auto and stick.
I believe the next time I'll be running at the track will be 8/18, I can't get there early enough on Fridays to make any runs.
Come on down.
Old Aug 8, 2001 | 10:11 PM
95CYC4's Avatar
95CYC4
Default Re: My First Post (Mr Mojo)
Thanks for the reply. I still don't understand why you shift at over 6000 rpm. And that was a high 13 second pass? I understand about the different mph, and the weather changes, but i'll talk to you more at the track. I did meet you at the SLP race at E-Town in August. I was racing my Impala SS. You are a nice guy and seemed to know your stuff about these cars, still got your card. I can't wait to race my car now. After doing my tune up stuff my car seems to run really good now. I am going to see my friend in MD this weekend and we are going to swap Vettes. He also has a stock 95. We want to see how each others car drives. I'll post my timeslips from E-Town as soon as I run it. I'll try to get there next Wednesday for some time trials, I would have gone tonight, but the track has the usual family day with jet cars or something. I will be at the next SLP day in October, and I think that i'll leave the Impala home and take the Vette down, there wasn't that many yellow Vettes there. I hope that you can make time at the track to answer all my questions. Be prepared for a serious q&a. I also plan on going to Carlisle with my MD friends, so maybe i'll see you there. And is there pre registration to go or anything like that? Just wondering, it will be my first time going. I can't wait. Thanks again for the reply, and what is the rev limiter set at on the stock LT-1's? I don't want to rev mine until it stops to find out. Talk to you later.
Old Aug 8, 2001 | 11:09 PM
Mr Mojo's Avatar
Mr Mojo
Yo Steve, I forgot to mention the shifting part. It is pretty much known that the factory tach is off. Sometimes by as much as 500 rpm. Mackey put an aftermarket tach and his is off by 500 rpm.
The rev limiter is set at 5850 I believe, so if I'm shifting at 6,000, my tach is off by at least 150 rpm, although I think it's closer to 300 rpm off.
I will be in Carlisle, you would be better off preregistering and trying to get a room will be hard this late in the game.
If you look at the August issue of GM Hi Tech, you will find me and Panuzzo on page 72 I think, it's from SLP day this year.
Old Aug 9, 2001 | 11:21 AM
95CYC4's Avatar
95CYC4
I will be driving up from my friends house in MD to Carlisle and driving back the same day. We are going on Saturday I think. He lives in northern MD, so the drive isn't that bad.
I will have to find that GM Hi Tech mag and take a look. I heard that there was an Impala SS in there also, I think that it was someone from our club.
Thanks for the info on the tach. I couldn't beleive how high you were shifting. I will install an after market tach to see how much my tach is off one of these days. Where do we splice off our tach signal? From our coil up front? Which part of the connector do you tap into? Any help on this would be great. I was shifting my car at 5500 yesterday on the way home. I chirps 2nd, 3rd and I think that I can get 4th to chirp, depends on the rpm. If I shift low(below 5000)it chirps with no prob, I guess the torque really drops off at those higher revs. I look forward to racing and checking out the Vettes in October.
I also got another question for you. My MAF connector fell off this week while I was driving. I had a service engine light come on, but there wasn't a noticable change in power from the car. Does this sound right? I reconnected it and the car seems to run like it did before, during, and after the disconnection. Maybe i'm getting too much sun....lol Does the Maf have that little control over the fuel delivery system that it wouldn't make any difference in performance? Or is my Maf shot. Or am I crazy. I think it can be all of the above. Thanks again and talk to you soon.
Old Aug 10, 2001 | 12:03 AM
Mr Mojo's Avatar
Mr Mojo
Sorry, I'm not much of a techie with this newfangled stuff, so I can't help you with those questions, but if Mackey reads this, I'm sure he can answer them.
As far as chirping gears, I can only chirp 2nd and occasionally 3rd.
http://www.corvetteforum.net/c4/mrmo...akinoffbg2.mpg
Old Aug 10, 2001 | 06:14 PM
95CYC4's Avatar
95CYC4
I saved the takingoff mpeg, it was cool. I think that you have better tires on the back of your car than I got on mine, so chirping 3rd is easier for me. If it wasn't raining today and I was going to see if I can chirp 4th, but it will have to wait for tomorrow.....had to drive the Impala to work, yeah my life is tough....lol Talk to you later, and get more videos online, I can't find Vette videos online that often.
Old Aug 10, 2001 | 10:24 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
For an aftermarket tach you can tap into the GREEN wire off the coil.
As for the MAF, I'm still not sure what rear effect it has on performance.
To Paging Mr. Mojo
