Power coupler L98
Old Jan 29, 2006 | 06:13 AM
corvette90's Avatar
corvette90
Default Power coupler L98
hi all
i modified my engine a bit, and put a 58mm BBK TB on it...
now, the "accordeon" wont fit, no chance, i can get it over the TB..
what are the power couplers made of, are they hard plastic, or something rubberlike, that i can work over the TB?
thank you
Old Jan 29, 2006 | 07:20 AM
countylawdog's Avatar
countylawdog
I have one on my 99% stock L98 - they are not expandable. I don't know how much more you need to expand, but if all else fails - buy - slowly and carefully heat the end you need to expand with a source of heat and make a custom fit.
Old Jan 29, 2006 | 07:55 AM
corvette90's Avatar
corvette90
are there "silicon couplers" available?
regards
Old Jan 29, 2006 | 08:03 AM
mseven's Avatar
mseven
Someone posted here awhile back with a company that makes some and custom but very expensive , the name escapes me but I will try and find it. I agree w/a heat gun going slow with a bar or tube from the inside to push it out a lttle at a time expand it. I have had good success using that method with hard lines, and rubber hosing to give factory appearance bends.
Old Jan 29, 2006 | 08:26 AM
jerkyboy's Avatar
jerkyboy
I believe the name is Samco.
Old Jan 29, 2006 | 08:47 AM
mseven's Avatar
mseven
That would be it !! must be gettin old
Haven't seen you post much lately, everything get resolved and dialed in?
Old Jan 29, 2006 | 11:20 AM
kopbet89c4's Avatar
kopbet89c4
Traffic cone murder.
Old Jan 29, 2006 | 11:44 AM
MrNuke's Avatar
MrNuke
The power couplers are made from a hard rubber material.Felixible to a point though. I was running one for years. I actually had to shorten it due to the superram and 52mm TB I was running, about an inch if not more..
What is different with your 58mm TB that you can't get the stock accordian around it? The lips should still be the same size as the 48mm ones just with larger bores inside..
Old Jan 29, 2006 | 12:55 PM
jerkyboy's Avatar
jerkyboy
workin' on it . Got it dialed in well enough that my new centerforce ain't holdin'
I had the same problem with my 58mm. Since I switched to Speed Density, I am using a '92 coupler and it is more pliable and fits ok. The accordian definitely won't fit without some riggin'
Old Jan 29, 2006 | 01:44 PM
GKK's Avatar
GKK
The speed density "Power Coupler" for "90-91" L98's, are made out of a rubber material. It can probably be stretched enough to fit on a larger TB, maybe use a heat gun.
Old Jan 29, 2006 | 02:35 PM
corvette90's Avatar
corvette90
Hi!!
the problem is, that the lip is much bigger than stock, and i had a hard time already to get it over the stock lips...
therefore i think its not possible to get the stock accordeon over it...
Old Jan 29, 2006 | 04:06 PM
77vetteuk's Avatar
77vetteuk
I posted here a couple of months ago asking the same question.Alot of members came back saying they had the same problem and to warm the end of the snorkel with some nearly boiling water or a hair drier to soften the end.
I used both,though it would no-way fit at first,went on in the end though after wrestling with it for ages.Fits way too tight though.
Old Jan 29, 2006 | 10:59 PM
89vettrr's Avatar
89vettrr
When I had the original air intake system and first upgraded to the BBK 52, I also found my stock "flex" would just not work, no way. At a glance you could see they were the exact same diameter opening. I bought the aftermarket smooth hi-performance coupler, heated in warm water, used the hair dryer and after what seemed like an eternity it finally went on......... Not sure that the 58 is bigger externally than the 52 but you might want to call the folks at BBK ?
Hang in there, the aftermarket hose should go on with twisting and persuasion
To Power coupler L98
