battery removal
Old Jan 30, 2006 | 10:22 AM
curtismoff's Avatar
curtismoff
Default battery removal
This is probably a stupid question but Is there some kind of trick to get the battery out of a 94 corevette?
Old Jan 30, 2006 | 10:45 AM
kalister1's Avatar
kalister1
I have read post's on this. The side panel (Body Panel) has to come off. The small panel with the louvers. Search around for battery you should be able to find it?
Old Jan 30, 2006 | 10:48 AM
curtismoff's Avatar
curtismoff
That is what I needed to know I thought maybe there was a trick to do this but I guess not.Thanks
Old Jan 30, 2006 | 10:53 AM
SJW's Avatar
SJW
As kalister1 correctly replied, the gill-vent panel needs to come off.
There are a few screws that secure the front edge of this panel to the inner wheelhouse panel. Remove them.
There is a screw that comes down from above to secure the top-rear corner (lift the hood and open the door to see it). Remove it.
And there's a screw that secures the bottom-rear corner. This screw comes up from below (you don't need to fully remove this screw, because the panel is slotted -- only loosen the screw a few turns and the panel will be free to slide out. To get at this screw, you'll need to drop the front end of the rocker panel. You don't need to remove the entire rocker panel, only remove a half-dozen or so of the front screws so that it'll drop down an inch or so -- then you can get at that bottom-corner screw with an open-end or box-end wrench through the gap. The rocker panel is pretty flexible.
Be well,
SJW
Old Jan 30, 2006 | 10:54 AM
jsaunde2's Avatar
jsaunde2
Remove the torx head screws joining the gill panel to the fender well. Remove the screw on the top of the gill panel near the door hinge. Then get a thing wrench to loosen the screw/nut in the slot between the gill panel and rocker panel. Then the gill panel slides out making battery removal a cinch.
Jason
Old Jan 30, 2006 | 11:42 AM
Red Dwarf's Avatar
Red Dwarf
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old Jan 30, 2006 | 01:11 PM
curtismoff's Avatar
curtismoff
Wow,I love this forum!!!!!!!!!! thanks again!
Old Jan 30, 2006 | 07:44 PM
ses86vette's Avatar
ses86vette
I don't know if yours is set up like my 86 but I was told that I had to remove a body panel to get my battery out..BS... I just unhooked my cruise unit and moved it out of the way, and the battery comes straight out of the top, with a little manuvering. 3 bolts and the battery was out of the car.
Old Jan 31, 2006 | 12:53 PM
jrp's Avatar
jrp
In his '94, the computer is directly above the battery and I'm certain that it would be a lot more work to clear a vertical path.
Removing the gill panel is not as big of a deal as it sounds. The hardest part is getting it aligned when putting it back on. I wasn't too keen on doing it in my '96, but having the extra room sure makes things easier. There is direct access to the hold-down bolt, and before moving the battery, I even found starting threads on the positive cable terminal to be a pain.
To battery removal
