How do I adjust my stick in the car. I think mine is a litte way off, because I have to press and hold the stick to keep it in first gear. Otherwise it will jump in to second. I am looking for a adjustment screw or something to tight or loose the wire going from the stick to the tranny.
Hope you can help..
It should be a cable adjustment at the control lever on the transmission itself. You will have to put the lever into 1st gear and adjust the cable to match.
