Universal Joints?
Old Jan 31, 2006 | 07:17 AM
GS348's Avatar
GS348
Default Universal Joints?
How do you know when they are bad? I feel a slight jar as my car just begins to accelerate and I'm getting the same thing as I deccelerate. Basically my drivetrain feels loose all of the sudden, c-beam is tight as well. Any ideas?
Old Jan 31, 2006 | 08:12 AM
Bigredwing's Avatar
Bigredwing
I'd like to know too. Mine is a 6-speed and I get a slight vibration and rumble near redline and above 65 MPH. I inspected the undercarriage and tried to rotate the driveshaft and half-shafts to see if there was any slop and didn't find any. As a matter of fact the drivetrain is very tight. Bad u-joints I've seen in the past either showed rusty deposits around the bearing caps or blown out seals. The only thing I saw on my car was a little bit of grease on the driver side half shafts u-joints which may be an indication that they are going. I don't know. One recommendation from another CF member was that I might have bad rear bearings which might be your problem too. So how do you tell, or do we just replace everything? Seems to me the half shafts might be easier to remove (for u-joint replacement) if the bearings are out.
Old Jan 31, 2006 | 08:38 AM
ittlfly's Avatar
ittlfly
For a bearing check, jack up the rear. Grab the tire at the 6 & 12 o'clock position. Try to rock the tire in and out. There should be no movement. Movement indicates a bearing problem.
The u joint can be checked with large screw driver placed in the trunion of the joint.
Old Jan 31, 2006 | 09:50 AM
vader86's Avatar
vader86
I noticed mine as a harder clunk when going into gear.
Old Jan 31, 2006 | 10:03 AM
jsinga's Avatar
jsinga
High speed vibration is definite sign if you sure it's not tires.
The outer ones go first of course.
The driveshaft u-joints don't move much. Mine looked new even after nearly 200kmiles in a street driven automatic. I'm working on the 3rd set of half-shaft u-joints.
With the yank test make sure your looking at wheel bearings slack not suspension movement. The factory manual says use a dial indicator with the wheel off. I think it's anything over .006" is history. Look in the book to be sure.
Old Jan 31, 2006 | 10:09 AM
Bigredwing's Avatar
Bigredwing
Duh! I didn't think of using a screwdriver to check for U-Joint shimmy! Thanks, I have a nice big one that should do the trick. I don't know if I'll be happy or sad with the results though. I guess it is better than leaving a flowing trail of parts .... Have a good day!
To Universal Joints?
